Easy way to raise/lower headlights
Old Feb 8, 2005 | 03:09 PM
  #121
sleet's Avatar
Ok, I adjusted them but i've now noitced that they aren't lined up 100% anymore, the left is higher than the right now. But when I put the socket on there, no matter which way I turn, they don't go up or down...any idea?
Old Sep 21, 2005 | 04:49 PM
  #122
UT_Evo's Avatar
Alright, I'm hoping someone will read this, but how long do you have to turn before they go up/down? I spent like 3 minutes turning my passenger side (and yes, it was turning, no stripage) and it didn't seem to move much at all.
Old Sep 21, 2005 | 04:57 PM
  #123
F&I-EVO's Avatar
if it didnt move its stipping!
Old Sep 21, 2005 | 04:58 PM
  #124
UT_Evo's Avatar
AKA The gear is turning just fine, really easy and quick, but the headlight doesn't seem to be going up or down.
Old Sep 21, 2005 | 05:06 PM
  #125
UT_Evo's Avatar
Bump, cuz we all know what will happen if i post a seperate topic for this!
Old Sep 21, 2005 | 05:21 PM
  #126
UT_Evo's Avatar
Bump again, I really want to fix this by tonight, if there isn't an answer after this bump though I will just post a new topic.
Old Sep 21, 2005 | 05:47 PM
  #127
SE7EN's Avatar
i did mines accouple days ago. i lowered my car drasticaly and damn i drove around and felt like i was going blind i wasnt able to see anything...now i can see EVERYTHING...i will take night time fotos and day time fotos of how i look ...or how others see me...h aha ha...everybody i hang with knows its me wether its day or night just cause of the bright *** lights...and ontop of that nobody ever high beams me for having or "looking like" i have my high beams on?? well ok ill upload fotos later
Old Sep 21, 2005 | 07:39 PM
  #128
rsboy's Avatar
Did it to mine 2 days ago and it works fine.
Make sure the lights are off and try to do the same amount of turns (you can hear it click when u turn it) on each side. I did about 5 turns at "0", checked it, lights off, turn some more, lights on.
Turn to the right, if u are facing the car. I guess u could say it's "counter clockwise" IF you were facing the actual gear/nut.
Went to level 2, lights on to check level, then off, turn about 3-4 times and found that level 2 is pretty much where level 0 (highest) was at before tweaking. My lights never tried to self-level it self the whole time I was turning the gears. It would only level(move) when u switch to different levels.
Pretty easy.
Old Sep 21, 2005 | 10:56 PM
  #129
UT_Evo's Avatar
So will it not work if the lights are on? What happens if you do it with the lights on, cuz that's what I've been doing? Didn't break anything I hope... cuz I've turned it like 5 times in a FULL circle (so like 500 notches) but the lights were on and it didn't do anything, so that would explain it if it won't work with the lights on, self leveling, is that what it is?
Old Sep 21, 2005 | 11:03 PM
  #130
RED DEMON's Avatar
with the lights on and the power to the HID motors, you could have striped the gears
Old Sep 21, 2005 | 11:36 PM
  #131
UT_Evo's Avatar
the gears were turning just fine and the only damage to the gears was done earlier when I tried to use too small of a torx to turn the gear (I'm only saying this because I have said twice before that I did NOT strip the gears at all)... but thanks for answering my question anyway.
Old Sep 22, 2005 | 05:53 AM
  #132
GOKOU's Avatar
If you have the 03 and 04 adjusting the highlights will suck. One is plastic where the other is metal. You tuen the metal piece to turn the plastic piece. THe plastic one is the one that will adjust the headlights. Metal against plastic is no good. The plastic one will strip. I had to remove the two phillip screw and manually turn the plactic knob to adjust it.
When adjusting I recommend you turn off the light and then adjust. Turn the light on and adjust again if necessary. Don't adjust with the light on.
On the MR I saw both were plastic. MIT finally got smart although why not make both metal.
Good luck.
Old Jan 13, 2006 | 08:09 AM
  #133
TurboErik's Avatar
Bright Lights, Big City!
Well, I guess it is my turn to try this free mod!
Totla time must be 30 minutes: 15 to read the posts and 15 to do the work.
Thanks.!
Old Jan 13, 2006 | 08:31 AM
  #134
RalliArtEvoVIII's Avatar
OLD...just search and theres tons of threads with info
Old Jan 13, 2006 | 08:34 AM
  #135
BushBurninEvo's Avatar
Good luck.
Save on cost I swapped out my headlight with another member, but his plastic gear was stripped so I'm driving around blinding people and getting high beamed at all the time
