fastest 1/4
Old Oct 23, 2003 | 10:27 AM
  #31
DynoFlash's Avatar
The huge variation on stock Evo 8 1/4 mile times seems to greatly support our position on stock Evo whp variation which we have seen from 211 whp all the way to 260 - bone stock
Of course if you believe Works - our dyno and testing methods are inaccurate - but my fat but dyno tells me my dyno jet dyno is right on the $ - also the timeslips show there are great variations from evo to evo
My theory is knock activity and high background engine noise on some individual evos is the cause. We do have some testing in progress to further isolate the cause.
Old Oct 23, 2003 | 10:53 AM
  #32
lrh's Avatar
lrh
I turned 13.39 103.60 last night. But that included a gallon of sunoco 100 racing gas. I also pulled out the air filter. Oh yeah, and the temperature was about 40 degrees.
Old Oct 23, 2003 | 11:12 AM
  #33
Silencer's Avatar
Al,
I have a question for you. Since your a 1/4 fan and I have been for 20 years, why is your time/mph slow based on your whp figures? I ran 10.90's at 124 mph with 478 whp and my car weighed 3852 w/ me in it. The time I can understand, but the mph puzzles me especially when you are 300+ lbs lighter and almost 100 hp stronger. I don't believe my torque figures are any higher because it was a short stroke large bore motor. What do you think? Thanks
PS. I also ran 9.92 at 138mph with 300 hp NOS jets (DFI motor).
Kind of off topic
Old Oct 23, 2003 | 11:20 AM
  #34
Rollaway's Avatar
I ran 13.3@101 stock with a 1.8 60ft
Old Oct 23, 2003 | 10:15 PM
  #35
en1gma19's Avatar
I don't know what kind of math gave you those numbers but I'll try and post my slip. Believe what you want, makes no difference to me. Either way I'm out driving wide open and sideways
Old Oct 23, 2003 | 11:02 PM
  #36
DynoFlash's Avatar
Originally posted by Silencer
Al,
Kind of off topic
Two reasons - one - I shift and launch super easy - my stock tranny has 11k miles and is still sound
and TWO - I only got ONE run in with that set up before they threw me off the track and that run has about the first 80' of serious tire spin
It should have been a low 11 second car back then - when it had the stock block
NOW - I have a fully built motor and head and it should be ready to go 10's if and when I ever get back to the track
Old Oct 24, 2003 | 06:06 AM
  #37
94AWDcoupe's Avatar
Believe me, it was hard for me to swallow and I was driving. Maybe I got one of the 'faster' EVO's. 0-60 1.699, 1/8 7.42. I'll try and get someone with a scanner to help me put the timeslip up.
I run 11.0s at 129mph and my 1/8th times have been no better than 7.35
Old Oct 24, 2003 | 06:55 AM
  #38
JaReDbOy's Avatar
ive had one track nite with 5 runs- my best was 13.8 and worst was 14.3.
when i was getting the 14's, it was very hot and humid, i finally got my 13.8 the last run and the temp had cooled considerably.
i dont consider myself to be an expert driver/shifter by any means- but i thought i had gotten really good runs.. i guess the temp really affects the 1/4 mi times- plus maybe i was really shifting as good as possible.
whoever said about spraying down the intercooler-- what exactly did you do? do you think that adds alot to the run?
also when you guys are shifting in the 1/4 mi- do you wind the engine all the way out to 7k rpm or shift earlier at like 5500?? i was almost redlining it when i was shifting- like 6500-6800...
Old Oct 24, 2003 | 08:22 AM
  #39
MrBonus's Avatar
Something doesn't add up for me either.
My old Camaro ran a 12.77@108.4 with a 1.92 60' (I don't remember the 1/8th) so I don't understand how he's running practically the same time with more MPH and nearly .2 second quicker launches.
Old Oct 24, 2003 | 08:30 AM
  #40
evosevengsr's Avatar
Originally posted by GokuSSj4
what are some of the mods that you have on the car ??
Im sure that 11.73 was accomplish on street tires / which type were you running ?
blitz boost controller(max boost @ 20psi)
apexi SAFC
razo cone air filter w/ heat shield
Full custom 3 inch exhaust
apexi barrel
turbo xs BOV
hks twin disc clutch,lightened aluminum flywheel
nitrous
yeah ..street tyres.the tyre name is Trampio(a brand of the Toyo tyre company)
it's a soft compound tyre...lots of grip!!! but wears fast!
blackevolution8
Sep 25, 2010 08:39 PM
usacchamp
27
Feb 16, 2008 10:59 PM
MR_EVO21
Jan 28, 2007 02:24 AM
monmashq
25
Dec 21, 2005 02:57 AM
