My 03 Evo 8 has stock turbo timer?
Old Dec 23, 2009 | 09:55 AM
Bens03vo's Avatar
Yes, I have had the car for about a month now and before I used to turn the car off and it would just shut off, and just last week, I had to disconnect negative battery terminal for maintenance and when I reconnected and started her up and test drove, and then parked and went to shut it off, and it stayed running with the key out and doors locked, it then shut off after exactly 30 seconds of after-run. I have searched and searched but have not found anything that tells me Evo's come stock with a turbo timer. Can anyone help shed light on this?
Old Dec 23, 2009 | 09:57 AM
bluebanana23's Avatar
no stock turbo timer.
Old Dec 23, 2009 | 09:58 AM
GSX_TO_EVO's Avatar
Does the car have an aftermarket alarm on it? Im pretty sure some of the alarms came with turbo timers
RockmanX's Avatar
Thats turbo timer NO its not stock you have one somewhere you just have to look in the cabin for it.
Old Dec 23, 2009 | 10:00 AM
ETS Michael's Avatar
Sounds like a turbo timer, does it only do it if the e-brake is up? I would start looking around the ignition area for a harness.
Thanks!
Michael
Old Dec 23, 2009 | 10:07 AM
Bens03vo's Avatar
If it does have an aftermarket one, Its hidden pretty darn good, but that doesnt explain why it never did it before I had to take off battery cable. and I have never parked without e-brake, I'll have to try that, Thanks
Old Dec 23, 2009 | 10:24 AM
UT_Evo's Avatar
Could be that it was set to not turn on before, and pulling the battery reset it to defaults?
Nothing on the stock car should keep it running, especially not for exactly 30 seconds every time.
Try it without the ebrake on, if that doesn't work... that's a better indication that it most likely is a turbo timer.
Old Dec 23, 2009 | 10:36 AM
gsrboi80's Avatar
If you cannot find the harness or the car does not have an aftermarket alarm. I'd look here for your answer. https://www.evolutionm.net/forums/in...lins-rain.html
Old Dec 23, 2009 | 10:50 AM
chaotichoax's Avatar
a lot of aftermarket alarms offer a turbo timer function
the glovebox is a common place to find a turbo timer
Old Dec 23, 2009 | 11:07 AM
Bens03vo's Avatar
Definitely isnt one in the glovebox lol...The car's mods that i was informed of when bought, was 3in TBE, open wastegate dump pipe, Forge MBC, and evo 9 mr BOV, AEM a/f gauge and prosport boost gauge other than that, car has 42,000 miles on it and everything else is mint stock. Im gonna search through the gremlin forum and see if i cant find anything, thanks again
Old Dec 23, 2009 | 11:41 AM
RockmanX's Avatar
even with my turbo timer RARELY it will shut off and not time down i think its done it 3 times since i have owned my evo but i know my has a timer is in plain view
Old Feb 21, 2013 | 08:33 PM
ashibonis's Avatar
The problem with your car not turning off
Your problem with your evo not turning off is that you have corroded wire connections where your wires come in through the firewall this happened to me. Your connections get water in them because of a bad seal if you don't fix them your horn will start honking itself and a lot of other things dash lights don't turn on or off your wipers will turn them selfs on and wont turn off and you get a lot of electrical problem hear is a link to the solution.
https://www.evolutionm.net/forums/in...s-how-fix.html
i did it myself its not too hard and im only 17
Old Feb 21, 2013 | 08:49 PM
one4's Avatar
Necro bump winner of 2013!!
Old Feb 22, 2013 | 04:57 AM
siikEvo92's Avatar
Hahahahaha^^^^
Old Feb 24, 2013 | 05:41 PM
ashibonis's Avatar
dick^^ i thought it might help then i saw it was from 09.... and non of you knew what the problem was.
Nesred22
Mar 30, 2017 09:54 AM
740 Turbo Brick
May 7, 2014 05:37 PM
swanky
May 26, 2010 09:16 PM
DontStopMe
Apr 10, 2009 09:46 AM
Srt-4 Turbo 7
10
Dec 21, 2006 02:28 PM
