Motor just blew
Old Dec 30, 2009 | 11:06 AM
ChuckP's Avatar
You're "experienced mechanic" beat the crap out of your car. In case you didnt know this already
Old Dec 30, 2009 | 11:31 AM
Ev0ikon's Avatar
How did you know about the faulty cam sensor? And as some have said, why drive it when you know of the problem?
Old Dec 30, 2009 | 11:56 AM
EvoJoeIX's Avatar
your stupid if your not going to make the guy driving your car pay for this engine
Old Dec 30, 2009 | 12:03 PM
DSMorBUST's Avatar
whos is your dads friend? and what is his shop called? if you already knew the cam sensor was bad.. why even drive the car?
Old Dec 31, 2009 | 08:08 AM
rickay726's Avatar
glad i got like zero help out of this thread so far, my engine just blew and everyone in this thread has done nothing to help thanks
Old Dec 31, 2009 | 08:12 AM
Genesis8's Avatar
Just look in the FS section...
Originally Posted by rickay726
i dont no what happened, my dads freind took my car to take to his shop to fix the camshaft sensor, next thing i no my car is flat bedded to my driveway with a huge hole in my motor idk how it happened he siad the piston just blew out of it, anyone no where i can get a new engine?
Old Dec 31, 2009 | 08:21 AM
ROGERV's Avatar
https://www.evolutionm.net/forums/sa...ck-engine.html
Good Luck.
Old Dec 31, 2009 | 08:25 AM
RockmanX's Avatar
there are plenty of used motors in the for sale section find one you like pick it up or ship it and install it problem solved. mine will be in there soon lol
Old Dec 31, 2009 | 10:29 AM
EvoJoeIX's Avatar
welcome to evom
Old Dec 31, 2009 | 10:31 AM
njboy's Avatar
Like others have said I think someone was beating on your car. Typically that's over reving and it is easy to do on the 4g63. Sorry, but these engines just don't throw a rod for nothing.
Old Dec 31, 2009 | 12:17 PM
italianevo88's Avatar
sounds like the most cost efficiant idea
Old Dec 31, 2009 | 12:25 PM
hotdog's Avatar
What exactly do you suggest we, as EvoM, your cohorts and friends, do for you?
Would you like me to send you money?
Old Dec 31, 2009 | 12:49 PM
Ev0ikon's Avatar
Ok. I'll help. Tell your dad's friend to give you the money and order an engine from one of the forsale thread on here.
But once it's back together, don't let him drive it again. And don't drive it at all if the CAM sensor showing some kind of issue. There!
Sorry I can't help you out with the money part.
Old Dec 31, 2009 | 01:15 PM
20gmr's Avatar
probly the cam position sensor, just like on buschur's RS. When it goes, its goes intermittently and gives the wrong rpm signal to the ecu, this causes the ECU to refrence the wrong cell in the maps and can cause severe detenation issues.
In buschur's case it lifted the head because the bottom end could handle it, in your case the bottom end couldn't so it broke a rod.
Shoulda towed it to change the sensor.
Old Dec 31, 2009 | 01:29 PM
andrewzaragoza's Avatar
if the mechanic knew that the cam sensor was going bad he shouldn't have driven it. it is easy to change the sensor.
