Motor just blew
Old Dec 30, 2009 | 10:05 AM
rickay726's Avatar
Motor just blew
i dont no what happened, my dads freind took my car to take to his shop to fix the camshaft sensor, next thing i no my car is flat bedded to my driveway with a huge hole in my motor idk how it happened he siad the piston just blew out of it, anyone no where i can get a new engine?
Old Dec 30, 2009 | 10:07 AM
TTP Engineering's Avatar
What kind of motor? Stock? Built?
The rod came through the block, not the piston.
Old Dec 30, 2009 | 10:08 AM
keevo54's Avatar
that sucks....sounds like ur friends dad messed something up
Old Dec 30, 2009 | 10:09 AM
bluebanana23's Avatar
a lot of variables, bad gas, dad's friend's driving, bad tune (doubt it), etc. Could be many things but don't jump to any conclusions/pointing fingers without investigating.
Old Dec 30, 2009 | 10:11 AM
Evo VIII 4G63's Avatar
call jnz tuning up they are in hatfield pa
Old Dec 30, 2009 | 10:17 AM
gsrboi80's Avatar
Your dads friend needs to "Pay Up Sucka"
Old Dec 30, 2009 | 10:18 AM
zeus1's Avatar
sorry to hear that. happened to me as well. just a fluke really as i was just cruising on the highway at the time...did a built motor for peace of mind..
gsrboi80's Avatar
Originally Posted by rickay726
\he siad the piston just blew out of it
Then there is this problem. If he really told you that he had no buisness working on your car anyway
Old Dec 30, 2009 | 10:22 AM
erald01's Avatar
the rod through the block mean the car has been pushed really really hard then prolly missed a gear or ever reeved it, because for a rod to go through am iron block it either takes a lot of power or missed gear/pushed hard on a unhealthy engine..
Old Dec 30, 2009 | 10:32 AM
rickay726's Avatar
the guy driving my car is a good freind and an experienced mechanic, the motor was not built, but i did have cosworth 272 cams done, the tune is 4ws so i highly doubt thats the problem, the oil that came out was straight black and i just did an oil change a month ago =( idk what to do
Old Dec 30, 2009 | 10:35 AM
kyoo's Avatar
sucks.. keep us updated!
Old Dec 30, 2009 | 10:38 AM
browningderek's Avatar
seems theres be a problem lately with cam sensors going bad. taking fuel and adding timing causing the motor to blow. thats not the first evo that threw a stock rod out the side ya know....... it happens.
Old Dec 30, 2009 | 10:40 AM
CoachG's Avatar
Your info says that you are in Freehold.
Turbo Trix is in Edison, Ivey is in Linden, both of whom could help out with finding & installing a new motor.
You might also contact DogBox Racing (in Howell) if you need someone really close.
Hope this works out for you.
Good luck.
Old Dec 30, 2009 | 10:46 AM
chaotichoax's Avatar
maybe someone with more knowledge can elaborate
but I'm going to go out on a limb and say driving on a bad/faulty camshaft sensor couldn't have helped the situation
Old Dec 30, 2009 | 10:52 AM
LI Pinky's Avatar
+1, also who installed your cams, and how long ago?! (mile wise)
