Does your EVO have a Rev-Limiter?
Old Oct 28, 2003 | 07:50 PM
Bad-Attitude's Avatar
I think the Mitsubishi Evolution VIII is the only Mitsu without a factory rev limiter. I have noticed this with at least 10 EVO's in that the owner's have pushed their cars up to 8,000 R.P.M. without any drama from the factory E.C.U. These were all stock cars BTW without re-flash or piggy-back bs.
Does your EVO have a rev limiter?
Old Oct 28, 2003 | 07:58 PM
MalibuJack's Avatar
I don't think thats accurate.. I'm uncertain if there is a rev limiter, but there appears to be a fuel cut according to several posts in other threads..
Old Oct 28, 2003 | 08:07 PM
Fourdoor's Avatar
The stock rev limiter kicks in at 7,500 RPM (+ or - 100) and is a fuel shutoff style limiter. Much less harsh than an ignition shutoff style limiter.
Keith
Old Oct 28, 2003 | 08:11 PM
Alfriedesq's Avatar
There IS a rev limiter that kicks in at exactly 7606 rpms
ALL evos have it
My Stage REV Dyno Flash can change it to any RPMS you want - we recomend 7800 max on stock engine - that give you more mph in 4th through the 1/4 mile
The base Stage Rev is going down in price to $79.99 just as soon as my web man posts it up on my page
Old Oct 28, 2003 | 08:13 PM
Keith
Really? Of the one's I rode in, they did not work. Each one was shifted at 8K with no rev limit or fuel cutoff.
Old Oct 28, 2003 | 08:22 PM
MalibuJack's Avatar
Are you sure? Mine definitely kicks in around 7600rpm.. when you hit it, you KNOW.. if you downshift its possible for the engine to go over the limit, but that has nothing to do with the rev limiter.. I don't abuse my car so I can't really say that I've payed much attention to it or attempted to see what it is intentionally..
Old Oct 28, 2003 | 08:25 PM
GMat's Avatar
could be the view angle from the passenger side made the rpms look higher than they were
Old Oct 28, 2003 | 08:27 PM
I considered that but then I drove the car myself and pushed it to 8K with no problems.
Old Oct 28, 2003 | 09:09 PM
Fourdoor's Avatar
Any guage cluster overlays? If he had to pull the needle and put it back on he f'ed it up
Keith
Old Oct 28, 2003 | 09:12 PM
umiami80's Avatar
I hit 8000 RPMS, what gives?
Old Oct 29, 2003 | 12:01 AM
mazdryk's Avatar
I also hit 8k RPMS no drop off at all just mad hp. I was going to post about the same exact thing today because people talk about fuel cutoff and rev limiters but ive taken mine to 8300 rpm.
Old Oct 29, 2003 | 12:57 AM
NRG's Avatar
NRG
Mine definitely has a fuel cut off even with my re-flashed ECU
Old Oct 29, 2003 | 05:26 AM
cdavy's Avatar
Registered User
Could this be a factory tach accuracy issue? I have a REV limit and my SAFC rpm monitor shows just over 7600 as Al said. My Integra Type R would show past 9K, but the cut was not that high. Seems like most factory tachs are less accurate the higher the RPM ranges. When I look at my SAFC compared to my EVO tach reading it starts to differ past 4K. Not sure how accurate the SAFC is, but I would guess it is fairly good.
Just my 2 cents
Chris
Old Oct 29, 2003 | 05:46 AM
evo8power's Avatar
mine cuts off at 7600
Old Oct 29, 2003 | 05:54 AM
is300's Avatar
Originally posted by Alfriedesq
The base Stage Rev is going down in price to $79.99 just as soon as my web man posts it up on my page [/B]
When is that price going to valid
