vented hood VS. non-vented
Subscribe
Feb 5, 2010 | 10:06 AM
If you drive your car in the winter engine heat is not that big of a deal. A non vented hood might be good to help keep the salt out of your engine bay.
Reply 0
Feb 5, 2010 | 10:08 AM
I just took the stupid black fake vent off and left the mesh there. 2 years like that and no issues.
Reply 0
Feb 5, 2010 | 10:36 AM
Too bad most CF hoods are heavier than stock so theyre pretty useless IMO, except for looks.
Reply 0
Feb 5, 2010 | 11:24 AM
Quote: Too bad most CF hoods are heavier than stock so theyre pretty useless IMO, except for looks.
And crappy 100k mitsu paint. My hood is def lighter than stock.
Reply 0
Feb 5, 2010 | 11:40 AM
are u crazy CF hoods are wayyyyy lighter! i have a sebion hood aswell n i was wondering if u could put the stock oem vent on the sebion hood?
Reply 0
Feb 5, 2010 | 01:07 PM
You have a evo with a non vented hood?
Reply 0
Feb 5, 2010 | 01:29 PM
+1, wanna see pics. i think its the oem style vent just closed off, for soe unknown reason
Reply 0
Feb 5, 2010 | 01:35 PM
Quote: are u crazy CF hoods are wayyyyy lighter! i have a sebion hood aswell n i was wondering if u could put the stock oem vent on the sebion hood?
guess you haven't been around long enough to know that most CF hoods manufactured were heavier than the aluminum stock one.
Reply 0
Feb 5, 2010 | 01:55 PM
Was the difference in weight tremendous or like a pound or two, I'm curious
Reply 0
Feb 5, 2010 | 02:14 PM
I haven't seen a evo with a hood with no vents whatsoever.
Reply 0
Feb 5, 2010 | 02:23 PM
the bad thing about no vent is that the heat rises there (where the vent is/should be). so you will see what the high temps will do to your hood in that general area. heat damage will destroy that hood from the inside. thats why theres a vent on the stock hood. to let the heat escape.
Reply 0
Feb 5, 2010 | 03:28 PM
you are correct sir, it is Seibon oem style. For some strange reason though the vent has no open slats in it. So I either need to dremmel them open or remove the part of the vent that should be louvered and open.
Quote: +1, wanna see pics. i think its the oem style vent just closed off, for soe unknown reason
Reply 0
Feb 5, 2010 | 03:32 PM
Stock hood owns all others.
Reply 0
Feb 5, 2010 | 03:46 PM
the stock hood looks awsome imho and no vent= no good
Reply 0
Feb 5, 2010 | 03:59 PM
the vents also have an aerodynamic purpose of allowing the air that is forced into the engine compartment through the intercooler and the radiator to escape out of the top of the hood. Otherwise the air would be forced under the car creating lift....lift= less traction= bad ....of course the effects of this are proportional to speed so at normal speeds effects would be minimal.
Reply 0
