Ballast, Bulb, or Wiring (HID Problem)
Old Feb 4, 2010 | 06:22 PM
Wht9er's Avatar
So Im having some troubles with my HIDs. One shines bright white (the way its supposed to) and the other has recently changed to pinkish color (and does not shine nearly as bright). Sometimes that light doesnt even come on at all, so I turn the lights on and off a couple times to make it work. What's my problem? Also any suggestions on different HIDs (inexpensive but decent)?
Old Feb 4, 2010 | 06:23 PM
Deathevn's Avatar
Might be the plug that goes into the bottom of the headlight enclosure. I had one "go out" so I bought a new pair of bulbs just to find that didn't fix the problem. The connector on the bottom had just wiggled a little loose. Hopefully it will be this easy fix for you : P
Old Feb 5, 2010 | 02:27 AM
MR. EVO MR's Avatar
When I bought my new hid fogs the drivers side with turn off and on by itself, I realized the conector was a little loose at the contacts, I shoved some small copper wires in the female side and all is fine since then.
Gl
Old Feb 5, 2010 | 02:37 AM
yahu's Avatar
This is common from my experience when inexpensive HIDs start to die. Unfortunately I didn't keep the vehicles long enough after the fact to even look into the problem; just replaced with the stock bulbs and sold within months (not because of the HID issue, just worked out that way).
I doubt it is the bulb and the wiring was all fine on my systems so I would put money on the cheap ballasts that most of the cheap kits run. Best of luck.
Old Feb 5, 2010 | 01:31 PM
boostin350z's Avatar
+1, on my g35 one started to die and turned a purplish, flickered, then would come on and off. it loses kelvins and changes color. i got a spare hid kit ill let go for dirt cheap if your interested
Old Feb 5, 2010 | 09:19 PM
SnyperZ's Avatar
I think if your car was faster you wouldn't have this issue.
Old Feb 6, 2010 | 04:28 AM
yahu's Avatar
^lol
akqowns
Nov 29, 2013 06:25 AM
ducvuu
Lancer Engine Tech
Aug 24, 2012 02:42 PM
Cornerstrike
Aug 3, 2010 12:16 PM
snobrdr2324
Jul 27, 2009 03:46 PM
JGAOZ
Lancer Troubleshooting
10
Mar 30, 2007 08:37 AM
