Popping out of gear...WTF
Old Feb 9, 2010 | 01:01 AM
EvolutinIX's Avatar
Originally Posted by Mike.p
or syncros?.......
I agree I would get a hold of the shop who built it.
Old Feb 11, 2010 | 04:45 PM
backcountryGSX's Avatar
Originally Posted by backcountryGSX
Very easy to get into gear...Just keeps popping out of first.
How bad is it for my car if I start in 2nd gear until this problem is fixed? This would include slight uphill starts.
If it matters, I have a ACT street clutch/flywheel.
bump
Old Feb 11, 2010 | 05:00 PM
Berts24's Avatar
starting in second will just put alot of wear on your clutch
Old Feb 11, 2010 | 05:05 PM
need_an_evo's Avatar
x2 never heard of anything like that before man. popping out while driving i have heard of that
Old Feb 12, 2010 | 12:54 AM
20gmr's Avatar
Just be mindful of the clutch starting in 2nd. i would say you could do it a few times just because im sure your problem is annoying but try not to do it back to back to allow the clutch to cool some.
As far as your problem goes I would check all the motor mounts. I know its sifter cable car but the engine can move around quite a bi tif one mount is not working.
Old Feb 12, 2010 | 05:16 AM
xtnct's Avatar
What happens if you keep pressure on the shifter in 1st gear location. Does it stay in gear then without problems or is there enough force to pop it out anyway or you just get feedback and feeling that if you don't move your hand, you will destroy something. Does it happen under low, high or no load (just driving at constant rpm)?
As a intermediate solution, you could try short shifting first instead of starting in 2nd (it will just be easier on the clutch). Start off in first and after literally 1-2 secs, shift to 2nd and keep going from low rpm's in 2nd. Basically, try to beat the pop out by shifting before it would pop out. That way you will not be slipping the clutch in 2nd that much to get going.
Old Feb 12, 2010 | 11:09 PM
^There's enough force to pop it back even with my hand there. Which sucks because I just had shoulder surgery and hurt my shoulder experimenting with that idea. It happens under all different loads but only happens if I'm starting from a complete stop.
I tried that short shifting idea, but it pops out of gear too soon to do.
So it sounds like it's a shifter linkage problem?
How much labor is involved in checking this/fixing?
The shop that did the rebuild is a 24 hour round trip and I won't be going back there til the summer. I'll have to go to a more local shop or dealership to have this taken care of.
Thanks everyone.
Old Feb 13, 2010 | 04:29 PM
sillyme's Avatar
tranny problems
your tranny is bad
Old Feb 13, 2010 | 04:36 PM
meckert's Avatar
[QUOTE=Steed77;7968600]Sounds like a synrco/blocker issue for sure.
Rt on the money. have seen this on several cars. Changed out sycros...problem solved.
warn synco's have 2 symptoms, one is grinding the other is popping out of gear under load. You do the the option of holding it in gear..lol
Old Feb 14, 2010 | 09:45 PM
Originally Posted by sillyme
your tranny is bad
I just had it rebuilt, it can't be bad. I'm guessing just one individual part is messed up because besides the first gear issue it feels great.
How much labor is involved to check the syncros?
Thanks
Old Feb 14, 2010 | 10:32 PM
vipevo9's Avatar
try looking at the cables if everything was properly adjusted
Old Feb 16, 2010 | 08:22 PM
Well, after waiting for a call back from the mechanic for 3 weeks I finally called back and got a hold of him. He was very defensive and basically tried to blame my short shifter for the problems(I've had a kartboy shifter kit for 4 years without any issues). He's going to have the owner of the company call me. The owner is a cool dude and has always taken care of me so I'm confident he'll handle this properly.
Ughhh I wish I had a DD lol.
Old Feb 16, 2010 | 08:26 PM
how much labor is involved doing this?
Old Feb 16, 2010 | 08:32 PM
Khazad's Avatar
I have had this exact same problem/symptom you describe (not in an evo). When the mechanic opened up my transmission, first gear was basically gone. I hope that is not the case here, just passing on what happened to me.
Old Feb 16, 2010 | 10:57 PM
^That can't be the case here since I just had the stage 2 Works tranny done. All new parts went in.
