Popping out of gear...WTF
Old Feb 6, 2010 | 06:57 PM
backcountryGSX's Avatar
Only happens from a dead stop in first gear. Pretty consistently...at least 5 times a day. When it happens I'll be able to go about 3 feet then it violently kicks back to the neutral position. Not only is it insanely frustrating but it's dangerous. I recently had a works stage 2 tranny put in and have been waiting for a call back for a while. thought I'd give the forums a try to see if I can gather any information about this.
Old Feb 6, 2010 | 07:05 PM
xspsi4's Avatar
could be a cable adjustment issue or a poor trans rebuild in which they reused a bad 1st gear where the engagement teeth are worn down.
Old Feb 6, 2010 | 07:16 PM
AviKM's Avatar
or something is against the linkages on the shifter on the tranny. this happened on my rsx. what gears are poping out, up only or down, or a mix?
Old Feb 6, 2010 | 08:25 PM
Mike.p's Avatar
or syncros?.......
Old Feb 6, 2010 | 09:29 PM
BLK_EvIL's Avatar
I would check all the linkages then see about gettin the tranny checked over
Old Feb 6, 2010 | 10:21 PM
SRT4toEVO's Avatar
sounds like a syncro to me
Old Feb 7, 2010 | 07:34 AM
xspsi4's Avatar
It would not be a syncro.
Old Feb 7, 2010 | 07:42 AM
nothere's Avatar
make sure the two ball headed bolts under the drivers side motor mount are in, and stock.
when I used the lighter sprung ball headed bolts for a special gear changer and then returned to the standard shifter (while still using the special bolts ) the car would drop out of gear once in awhile under load.
if that is not your situation, I would think a shifter linkage adjustment might be in order. thinking the linkage is not getting fully into gear. (in first anyway)
Old Feb 7, 2010 | 10:27 AM
srt4evah's Avatar
Friend of mine had this same issue, it turned out the tranny cables were twisted. Replaced cables, problem gone.
Old Feb 7, 2010 | 12:18 PM
AviKM's Avatar
when my syncros went, i couldnt go into gear at all, there was a wall in 4th and reverse
Old Feb 7, 2010 | 12:23 PM
Lowso's Avatar
i say syncros i feel that problem coming also to my rsx.
Old Feb 7, 2010 | 12:34 PM
oneofakindtrini's Avatar
Could it be the syncros? I don't think so. Probably a problem with the shifter linkage of some kind.
If it was the syncros it would be able to go into gear?
Old Feb 7, 2010 | 04:15 PM
Steed77's Avatar
Sounds like a synrco/blocker issue for sure.
Syncro... helps it go in
Blocker... keeps it in
Old Feb 7, 2010 | 11:20 PM
boostin350z's Avatar
yea if your synchros went, itd be extremely difficult to get into gear, if at all. id check your cables as stated above
Old Feb 8, 2010 | 10:55 PM
Very easy to get into gear...Just keeps popping out of first.
How bad is it for my car if I start in 2nd gear until this problem is fixed? This would include slight uphill starts.
If it matters, I have a ACT street clutch/flywheel.
