Caution : Dealership says to watch....
Old Oct 31, 2003 | 09:30 AM
meisnerboy's Avatar
This sounds like it could be a fast break-in vs slow break-in issue???
If you burn/loose oil quickly could you please post if you did a hard or easy break-in as well?
Old Oct 31, 2003 | 09:31 AM
GPTourer's Avatar
My car does not eat oil, nor have any of our Evo customers repoted any excessive oil consumption.
Old Oct 31, 2003 | 09:34 AM
Karash's Avatar
another urban legend is born!
Old Oct 31, 2003 | 09:44 AM
WildRice's Avatar
The evo is my third mitsu since "00" . None of these (Diamonte, Eclipse gt, Evo) cars uses any noticable amount of oil between the 5k changes. If yours does you have a serious problem. Excessive oil consumption should be a warranty issue, rings not seating, valve seal leaks, or gasget problems. It ain't normal guys. Yes I drive fast.
Old Oct 31, 2003 | 09:48 AM
93civEJ1's Avatar
just telling you guys what the mechanic told me, and i thought it was kind of odd since my buddy and the other dude both blew theirs,??? I dont know how well that mechanic know what he is talking about, but he said that is just word from Mitsu.
Old Oct 31, 2003 | 10:40 AM
DoingAnything's Avatar
Originally posted by jbrennen
Definitely check the oil regularly and carry a quart of your favorite synthetic oil in the car. In my RX-7, I got in the habit -- it was practically a requirement to carry oil and check the level regularly, since it would burn a quart every 600 - 1000 miles.
As another RX7 owner you should know that the rotory engine sort of works like a 2 stroke motor, it doesn't burn the oil, it mixes it w/ the gas and its normal. Only thing I religiously check on my FC and FD is the dam coolant... thats what worries me.
Old Oct 31, 2003 | 10:43 AM
NYEVO8's Avatar
if your car is loosing coolant, then you got some problems there.
maybe gaskets or simply a tube is leaking.
Old Oct 31, 2003 | 11:24 AM
not saying that i'm losing coolant.... just worried about overheating the car... rotory+overheating=instant engine "boom"(for a lack of a better word).
Old Oct 31, 2003 | 11:41 AM
trev0006's Avatar
Out of every car I have owned. (porsche's, audi's, bmw's, and many japanese cars) the Evo has eaten less oil, in fact in about 3k miles it has not eaten a drop, this is a great engine.
Old Oct 31, 2003 | 11:54 AM
EVOMIZ's Avatar
my evo eats about 1/2 quart right before i have to get the oil change ( about 2500 miles into the oil change). so did my 300zxtt.
I drive very hard I get about 170 miles per tank of gas.
Old Oct 31, 2003 | 12:04 PM
prowler's Avatar
1400 miles, and its still completely full..
I broke it in per manual. Last night I took it to 8,000 rpms (indicated) , my tach must be a bit off as well.
Old Oct 31, 2003 | 12:16 PM
Bogie's Avatar
Mine eats more oil than any car I have ever owned, including my '93 zxtt, which barely ate any. I guess I can say it was a moderate break-in, just as with the z.
Old Oct 31, 2003 | 12:30 PM
raidersevo8's Avatar
THANKS MOTOMAN. Im up to 2500 miles again so i checked my oil and not a drop gone. I pushed my car hard to 5k rpms from miles 7-50. I always went WOT on the gas but never took it over 5k rpms so i was putting pressure behind my rings to get them to wear evenly while not taking it over 5k rpms which mitsu advised. THen changed my oils at 500 miles and again at 1k miles. I only went to 7k rpms 2 times when i was at the 450 mile mark and 750 mile mark.
Old Oct 31, 2003 | 12:39 PM
spyderturbo's Avatar
I'm upto 17,500 miles. I notice about 1/2-3/4 of a quart is gone between my 5k oil changes. Cant complain about that..
I did my break in per mitsu's specs.
Old Oct 31, 2003 | 12:54 PM
yycools's Avatar
correct me if I wrong, but won't the oil light come up if you're really really low on oil?
