Balance shaft removal?
Old Feb 20, 2010 | 08:57 AM
boostfreak8's Avatar
Has anybody ever heard or removed their balance shafts on their evo for horsepower gains, better engine response, more oil capacity.. and so on. My question is would there be any dangers to doing this?
Thanks Kris
Old Feb 20, 2010 | 09:31 AM
houdini_678's Avatar
Balance shaft removal alone? Don't do it. An eliminator Kit, sure. Removal alone increases the chance of belt and oil pump failures caused by eliminating the support provided by the rear bearing journal.
Old Feb 20, 2010 | 09:55 AM
Brokenevo's Avatar
Get with AMS they have an eliminator kit you NEED. There is no option at all. I warped my long time ago and had mine replaced with the kit. There is actually no danger from going to the kit, but billions of reasons why to do it. there is some power gained maybe like 15hp max, but if the oil pump decided to go, with the kit the engine is likely to be saved. That happened to my motor, when I sold it to another member, he screwed up and caused the motor (oil pump) to blow and the only thing that saved that engine was the elim kit. If its not going bad yet, dont do it lol. It cost me $1800 in parts and labor!
Old Feb 20, 2010 | 02:17 PM
chaotichoax's Avatar
search
and as others have said you don't simply just remove them
closed...
babaz7
Jun 5, 2013 07:16 AM
4RETECH
11
Apr 10, 2013 10:42 PM
phil_
Lancer-Mirage Compatibility Forum
Oct 22, 2011 10:12 PM
MitsuJoe
11
Sep 21, 2007 02:32 PM
