Hand brake and rear pads....
Old Feb 23, 2010 | 12:29 PM
Manu9331's Avatar
Question Hand brake and rear pads....
Hello,
Often when I take my Evo and that I leave it a few days without rolling, I have the brake hand, finally the back brake pads remain stuck.
Is this normal?
Old Feb 23, 2010 | 12:32 PM
evolutioner27's Avatar
Mine stick a little bit too if it has been sitting a couple of days and it rained or snowed out. They break free right away when I start moving. Seemed normal to me.
Old Feb 23, 2010 | 12:35 PM
Brsox10288's Avatar
Yeah this is normal. Mine sits for weeks at a time. When I let the parking brake down and go to move, it almost makes a clanking noise from the brakes where the pads are breaking loose. Dont worry about it
Old Feb 23, 2010 | 02:07 PM
Manu9331's Avatar
ok thank you guys
Old Feb 23, 2010 | 02:13 PM
Manu9331's Avatar
I also have the impression that when I tighten the brake hand I must draw thelever very high.
Must I regulate it?
Moreover it does not seem to brake very much.
A solution?
Old Feb 23, 2010 | 02:17 PM
Kracka's Avatar
Remove the center console and adjust the cable. Its a total of 2 screws and 2 plastic clips.
Old Feb 23, 2010 | 02:22 PM
Manu9331's Avatar
Do you have a pic of this?
Old Feb 23, 2010 | 02:34 PM
AIEvo9MR's Avatar
If your pulling the hand brake that high, its best that you adjust the parking brake drums. It will not do you any good to adjust the center console bolt. Its very easy to do.
Old Feb 23, 2010 | 03:19 PM
AIEvo9MR's Avatar
Parking Brake Adjustment
Ok so this is what your going to do. Place two blocks on the front wheels because your going to lift the evo using your diff as your lift point. You need to have both rear wheels in the air to do this.
Remove your wheels. You do NOT need to remove your caliper and rotor.
Remove the small piece of rubber covering the access hole on your rotor.
Turn the rotor until the access hole is at the very bottom.
Inside you will see a star like screw that needs to be turned counter-clockwise. That's means pushing the bottom of the screw in.
After a few clicks, try and turn your rotor. Continue until you can't turn the rotor.
Once the rotor is unable to turn, loosen the adjuster 3 or 4 clicks.
Now go and do the other side.
Remember to reinstall the rubber access cover on the rotor and put your wheels back on. Remember to torque your wheels to 75 foot pounds (100 newton meters.)
Now try your hand brake.
Old Feb 23, 2010 | 03:30 PM
revvin9k's Avatar
Originally Posted by AIEvo9MR
If our pulling the hand brake that high, its best that you adjust the parking brake drums. It will not do you any good to adjust the center console bolt. Its very easy to do.
THIS!!
Why people continue to do it from the center console boggles me. Granted, the cable may stretch a bit, but I have ALWAYS done it from spindle behind the rear rotors, as stated above.
ak47po's Avatar
Old Jun 13, 2021 | 03:51 PM
baegopa's Avatar
Omg thanks i didint know that one i was gonna undo the whole thing!!!!
Old Jun 13, 2021 | 06:56 PM
barneyb's Avatar
From the factory my parking brake had very little holding power. I could back out of my driveway and not notice it was applied. After years of driving I finally needed new rotors and while in there I decided to adjust the parking brake. Night and day difference.
invecs
Apr 13, 2016 10:04 PM
PMPN8EZ
Mar 27, 2016 08:15 AM
Randal
13
Dec 23, 2012 09:14 PM
wickedwhite860
11
Nov 30, 2007 08:55 AM
jimmyv65
Sep 4, 2003 03:07 PM
