for those running mini batteries
Old Feb 24, 2010 | 01:31 PM
  #31
Kracka's Avatar
Great way to shave weight and clean-up the engine bay.
My car started every time, even on the -10F MN winter days.
Old Feb 24, 2010 | 01:38 PM
  #32
mdsevo06's Avatar
I've had mine for two years with zero issues and this is my DD. Then again, I'm in San Diego. If I was in a cold state, I would relocate.
Old Feb 24, 2010 | 03:28 PM
  #33
EvoJoeIX's Avatar
Originally Posted by DetroitEvoIX
I think the whole 'mini battery' thing is a bad idea, especially when swapping out the OEM upper intercooler pipe has not proven to provide substantial gains.
"Let's see..........I'm going to spend XXX.XX dollars for something that gives no noticable HP improvement, but the trade off is my car may not start on a cold morning"
To each his own, but I think this is a bad idea.
thats why if you relocate it to the trunk you get the best of both worlds. just takes a little bit of work.
Old Feb 24, 2010 | 03:38 PM
  #34
tarmac03's Avatar
mini battery
my buschur mini is 2 years old ,car sits for several weeks at a time,i live on the east cost and have no issues!!! go for it besides it looks cool
Old Feb 24, 2010 | 04:44 PM
  #35
CharlieGsanD's Avatar
as long as you don't mind replacing the mini-batt every 2 years or so at around 95-135$ a pop then go for it
the batteries are only rated for 2-3 years max unless you run a float charger to keep voltage above 13.2-13.8 or so according to odysseys own specs. given that i am on my 3rd battery in 6 years, id say this recommendation is pretty spot on
if you use it as a DD then it may still start & run after this duration, but in my experience after two years they seems to have problems maintaining full voltage & you may experience breaking up under boost, hard starting & if left sitting long enough it will run down the voltage & not start
Old Feb 24, 2010 | 07:22 PM
  #36
Routybouty's Avatar
Same, except I have my own special 4lb battery
Old Feb 24, 2010 | 07:29 PM
  #37
Evoguyfhp's Avatar
0 problems with mine unless i let it sit i like it.. I still might relocaate to the back later just to put an oil catch can there lol!
Old Feb 24, 2010 | 07:33 PM
  #38
localtoys73's Avatar
have the ets kit and ets short route uicp, looks great and has been fine so far, i only run the car once a week at most
but i do live in florida
Old Feb 24, 2010 | 07:50 PM
  #39
Foolproof's Avatar
I am about to relocate to the trunk but with a red top. Dont feel like risking the "little" battery.
Old Feb 24, 2010 | 07:52 PM
  #40
NJ9MR's Avatar
FCOTM Winner
For wiring, you should run 1 gauge wire! It is safer!
Old Feb 24, 2010 | 07:57 PM
  #41
Q8_EVO's Avatar
AMS mini battery for three years now with no problem.
No issues with the cold when i was in Idaho.
Old Feb 24, 2010 | 08:27 PM
  #42
chrisevo8's Avatar
ams mini battery for 3 years. no problems. when its super cold doesnt turn over like in the summer but still gets the job done. i also only drive my car once a week and its fine.
Old Feb 24, 2010 | 08:38 PM
  #43
kyoo's Avatar
Same opinion if you garage the car? I only drive once a week or less, but I do hook it up to a trickle for longer waits
Old Feb 24, 2010 | 08:42 PM
  #44
Boosted Tuning's Avatar
Originally Posted by ETS Michael
Why are you relocating the battery? Why not keep it in the engine bay? You can run a stock route piping kit and the stock battery will stay. The only problem I see is if you relocate the battery to the trunk.. depending on the track.. You may need to install a cut off switch on the outside of your car or they will not let you run. I would double check with your track first. If you do this, make sure you get a removable switch so people don't tamper with your car in the parking lot. Hate that..
Thanks!
Michael
+1
Running an ETS mini battery kit in my EVO. Even when I dont drive my EVO for a couple days, it still starts fine.
Old Feb 24, 2010 | 09:13 PM
  #45
dasmyevo88's Avatar
how much is a mini battery and what brands make them?
