for those running mini batteries
Old Feb 26, 2010 | 12:30 PM
  #61
thatmr2guy's Avatar
Why dont you just get a miata battery they are smallish and provide pleny of CCA. Plus when it does die down the road its easy to replace. All you need to address is customizing the braket. I am sure that if you do your homework you could find a 'lighter' that normal miata battery without going into the mini battery zone.
So maybe you save 5-10lbs off the front of your car......
Old Feb 26, 2010 | 12:46 PM
  #62
EvoJoeIX's Avatar
Originally Posted by H-TUNER
Proper size in the trunk is definitely the best. Front looks much better w/o the battery there & of course, the weight distribution is better. Should mount it in a closed box, vented to the atmosphere. This is so that any battery(acidic) vapors can exit the vehicle, so they don't; eat any upholstery, and don't accumulate and create any other hazard. Especially in hot climates.
battery box is on its way here
Old Feb 26, 2010 | 12:50 PM
  #63
broeli's Avatar
I have had the same Odysey PC680 battery for 4 years and even after sitting 2 weeks in the cold Ohio winter it starts. It's been GREAT. I've had worse luck than that with full size batteries after they are this old..my mini battery is still going strong.
Old Feb 27, 2010 | 12:24 PM
  #64
motorspt's Avatar
I have a brail mini-battery, and on a SUPER cold ( <20) degree day, I have to jump it, other than that, sometimes it's a little slow to crank on cold day. I think the weight-savings is worth it though.
Old Feb 28, 2010 | 04:23 PM
  #65
suprakiller's Avatar
if you drive (start) your car everyday, a lightweight battery might be ok, but if you leave it sitting for 4-5 days, it will probably be dead (15 lb battery). prepare for a lot of jumps. the weight savings are really not worth giving up the piece of mind that your car will definitely start (esp. for a street car imo.)
Old Feb 28, 2010 | 08:24 PM
  #66
Boosted Tuning's Avatar
I have a mini battery and I leave my evo sitting for 2-5 days all the time. Still start right up, even in 30-40* (even though thats not that cold)
Old Mar 7, 2010 | 11:01 PM
  #67
amsevokid's Avatar
i have a gutted trunk, so if i relocate the battery to the trunk can the plastic battery tray prevent the battery from draining by sitting on metal?
Old Mar 7, 2010 | 11:31 PM
  #68
UsafEvo's Avatar
going on 1 week with a kinetik mini battery still works fine for now haha
Old Mar 7, 2010 | 11:48 PM
  #69
2slow4u's Avatar
I have the ETS mini battery and have no complaints. I had it during the neg 10 degree weather in the winter and had no problems.
Old Mar 8, 2010 | 01:16 AM
  #70
stwhollywood's Avatar
i have had no issue with my mini battery. car even sat for over 2 weeks in the snow and cold and it started right up first try. I am happy with it so far
Old Mar 18, 2010 | 07:37 PM
  #71
91TSiGuy's Avatar
I've ran a PC680 in my Evo for a bit now. It was in there about a year when I first bought it, then I put it in my drag Talon for a year or two and drained it a bunch of times trying to work on the cold start settings and then used it in my Evo again after buying it back a little over a year ago. It only needed a jump once this past winter after letting the car sit outside in ~20* weather a few consecutive days but was fine being used every day though.
I recently upgraded to a JMF PC925 battery kit and still have plenty of room for aftermarket IC piping. (which I still have yet to make for myself ) It cranks strong like the stock battery, weighs less, and takes up just a tiny bit more room than the 680 did.
Old Mar 19, 2010 | 01:30 PM
  #72
JustJeff's Avatar
I run the Deka $60 Battery. Had it for about 6 months, other than a few times of it not turning of fast. it works great. This is of course after turning the car on and off 2-3 times within a half hour. If you just need turn on power, a mini battery works, I would have done a trunk kit if I didnt get that Battery for $60 bucks. I made my own tray for $1 using the stock tray and some bolts from homedepot.
Ralliartize It
Dec 5, 2012 08:07 PM
bbak11010
Feb 28, 2011 05:51 PM
*chris*
Automotosports - Illinois
Feb 20, 2006 12:33 PM
AlwaysinBoost
Dec 18, 2005 01:21 PM
caymandiver75
16
Jun 30, 2004 09:43 AM
