evo wont stay running
Old Mar 4, 2010 | 03:05 AM
040160's Avatar
almost forgot...
also curious if, during times it stays running sluggishly, does it sputter ("phrrrrrr" sound)? if so, check to be sure your plugs are ok and are gapped correctly. also see if the coil pack and plug wires are fine.
Old Mar 4, 2010 | 03:38 AM
jos's Avatar
jos
did u check for vacum leaks on the intake manifold manifolds u may have a brust vaccum line and check the maf sensor to see if it is reading the incoming air properly. trouble shoot there areas., and the tps too
Old Mar 4, 2010 | 05:34 AM
mitchroxz's Avatar
Originally Posted by 040160
almost forgot...
the first time i had these issues i could get it to run sluggish when i disconnected the IAC motor. this most recent time i cant get it to stay running no matter what i do unless i constantly have my foot on the throttle.
Old Mar 4, 2010 | 09:16 AM
vipevo9's Avatar
recerculate the bov if its not done already, got a problem with my car front o2 is not ready making the idle funky and drop
Old Mar 4, 2010 | 09:27 AM
mitchroxz's Avatar
i have my other bov which is the APS twin vent. I think im going to hook that back up and recirculate it to see if that fixes the problem. i probably wont be able to do that until this weekend so i will keep everyone posted and let you know what comes from it.
Old Mar 4, 2010 | 09:31 AM
CBRD's Avatar
Originally Posted by mitchroxz
ive been trying to get a hold of CBRD. I only live about 40 minutes away from them. I'd like to see if this will fix it though before I have to reach into my pocket and pay someone else to look at it haha.
pm sent,
i havent had any messages regarding an evo with these problems!
cb
Old Mar 4, 2010 | 10:00 AM
mitchroxz's Avatar
Originally Posted by CBRD
pm sent,
cb
i dont know if im just unlucky but i havent got any pm's from you lol.
Old Mar 6, 2010 | 01:02 PM
mitchroxz's Avatar
ok i got my old bov hooked back up and a new o2 sensor in the car. it still wont stay idling. im doing a battery reset right now to see if that fixes it. any other suggestions?
Old Mar 7, 2010 | 10:36 PM
amsevokid's Avatar
try a fuel pump fuse, my firends 03 was doing the same thing then he changed the fuse and its fine now.
Old Mar 8, 2010 | 08:09 PM
jos's Avatar
jos
do u know anyone with a diagnostic to have them look it and get a error code
Old Mar 9, 2010 | 05:38 AM
mitchroxz's Avatar
ill have to look at the fuel pump fuse. yes i do have a friend that can bring home a scanner and read the codes. the only problem is after reseting the battery i cant get the car to throw another code.
Old Mar 9, 2010 | 08:32 AM
churbo's Avatar
Post a vid of it
Old Mar 11, 2010 | 12:36 PM
mitchroxz's Avatar
id be more than happy to do that....however it may be a while. my car is in the shop right now for body work because of an accident that happened over the weekend. as soon as i get it back ill take a video of the problem!
Old Mar 25, 2010 | 08:18 AM
mitchroxz's Avatar
for those of you who were wondering what was wrong with my car I finally got it fixed! It turned out to be a few issues. The biggest problem was a firing issue with my spark plugs. We took the old ones out and put a new set in. The car would finally stay idling but very sluggish. We adjusted the throttle and the car is back to running like a champ again!
Just thought I would share with everyone that was following this.
Old Mar 26, 2010 | 06:33 AM
mitchroxz's Avatar
ok so i thought the problem with my car was fixed haha but its not . the mechanic working on my car now thinks it might be MAF sensor related. they said my MAF sensor is not reading the correct temps. the car does not stay running in the cold weather in the morning but as the day goes on and the temp outside heats up they said it starts up fine and stays idling like a champ. does this sound like its my MAF sensor?
Boombox
32
Jan 23, 2016 02:34 AM
Tobra
Lancer Troubleshooting
Feb 20, 2015 05:24 PM
bnice01
32
Sep 13, 2013 02:09 PM
newimportowner
Dec 12, 2011 12:54 PM
ch53avitech
10
Feb 13, 2010 11:10 AM
