question: RPM's at highway cruising speed????
Old Nov 4, 2003 | 10:28 AM
jed's Avatar
jed
Noticed on the highway, the rpm's at 70mph equal 3Krpm and at 80mph equal 3500rpm in fifth gear. This is cool since I have immediate turbo available for passing, but I was wondering if this was normal. All the other cars I owned usually dropped rpm's down to around 2500 when in fifth for gas conversation on the highway which would mean I would have to shift into 4th to pass anything.
Thanks,
Jed
Old Nov 4, 2003 | 10:34 AM
jotan82's Avatar
yup, 80 is right at 3500
Old Nov 4, 2003 | 10:36 AM
customlancer's Avatar
my automatic oz does about the same(in its top gear{4th}). i know its a completely different car but that sounds ok!
Old Nov 4, 2003 | 10:40 AM
Secret Chimp's Avatar
It is normal.
The gears are set up such that each gear change puts you right into the sweet spot where the power is...which is how just about every race tuned car should be.
Usually only commuter comfy cars make the 5th gear a highway gear. Those cars put the gear change into 5th right where the best fuel economy is.
Old Nov 4, 2003 | 10:46 AM
jbrennen's Avatar
Yes, your car is normal and your numbers are right.
Given the tires 235/45R17, the 5th gear ratio of 0.72, and final drive of 4.53...
We get:
Tire diameter = 25.33 inches
Tire circumference = 79.57 inches
Tire circumference = 6.63 feet
At 1000 RPM, the engine turns 16.67 times per second. The wheels turn 16.67/(0.72*4.53) = 5.11 times per second.
So the ground speed at 1000 RPM in fifth gear is 33.88 feet/second, or 23.10 MPH.
70 MPH = 3030 RPM in 5th gear
80 MPH = 3463 RPM in 5th gear
Old Nov 4, 2003 | 10:50 AM
SAEVO's Avatar
5th gear....... 55mph 2,500rpm and 80mph 3,500rpm.
those are the only two speeds I go.........
Old Nov 4, 2003 | 07:24 PM
GotBoost25psi's Avatar
man somebody paid attention in math
We get:
Old Nov 4, 2003 | 07:29 PM
Quickshift's Avatar
No Doubt
Old Nov 4, 2003 | 11:50 PM
ds18's Avatar
Can someone please explain to me why it takes a long time to reach the set boost on the 5th gear?
Thanx.
Old Nov 5, 2003 | 05:56 AM
You should be asking that question in the newbie forum or in the Evo engine/ tech forum.
SC~
Old Nov 5, 2003 | 06:12 AM
4-BNGR's Avatar
80 for me is at 8100rpm
Old Nov 5, 2003 | 07:36 AM
mayhem's Avatar
Thanx.
Hmmm..I hit max boost instantly in 5th.
Car manufacturers purposely put you somewhere in the main power band on purpose. LIke mentioned earlier it's for passing which also goes for safety.
But also you need to be able to climb a hill with all accesories on (a/c, lights, wipers, rear defroster) without switching gears. Highway cruise that is.
Old Nov 5, 2003 | 07:40 AM
jotan82's Avatar
in third gear?
Old Nov 6, 2003 | 01:53 AM
ds18's Avatar
Roger, Moderator!!
Rasperin
May 8, 2017 06:11 PM
JED_POLAND
14
Dec 29, 2009 12:31 AM
AlwaysinBoost
Jan 4, 2006 04:09 PM
evojed
12
Apr 28, 2004 07:17 AM
jed
25
Oct 26, 2003 09:45 PM
