Leaking tranny fluid after clutch change
Old Mar 16, 2010 | 08:16 PM
dmcghie's Avatar
So I got my clutch changed over the weekend....broke it in for about 250 miles....then decided to open it up today. But every time I get on it I smell transmission fluid. There is also a small puddle underneath the car when I park. Anyone had this happen to them before? I'm guessing either one of the o ring gaskets went bad or my mechanic put too much fluid in the transmission/transfer case.
Old Mar 16, 2010 | 09:02 PM
mr.almeida's Avatar
Drain/Fill bolt could be loose or they didn't clean the tranny after filling it.
Old Mar 17, 2010 | 08:22 AM
barneyb's Avatar
missing oring
Old Mar 17, 2010 | 08:48 AM
thedru13's Avatar
x2. Pull the tcase and see if the oring is gone. I tore mine twice when I was installing my tranny. Here are the part numbers I would recommend you fix this sooner than later unless you want to replace your tcase anytime soon..
MD743612 o-ring between transfer case and transmission small
MD727944 o-ring netween transfer case and
Old Mar 17, 2010 | 08:55 AM
delongedoug's Avatar
+1 to o-ring but get under the car and see where it's coming from. I bought a pair of each o-rings when doing my tranny in case we busted one up. A month later my friend needed the same o-ring and I had one handy. Lesson: Always buy a spare of what you need. I'm heading to Mitsu now to pick up a couple nuts and bolts and am buying 2 of each, just in case.
Old Mar 18, 2010 | 05:19 AM
dmcghie's Avatar
problem solved guys......O ring was bad which i should've changed since the car has 62k on it. Thanks for the suggestions.
Ghilversumtuner
Lancer Tranny/Drivetrain Tech
23
Apr 11, 2019 09:28 PM
Lucas Mendoza
Aug 22, 2017 07:01 PM
kevin salazar
Jul 31, 2017 04:01 PM
Evol Darwin
Nov 28, 2014 12:48 AM
Hanzo
May 12, 2004 08:27 PM
