VIII outlet pipe on IX turbo?
Old Mar 24, 2010 | 03:22 PM
badev0's Avatar
Can I use the outlet pipe off my VIII turbo onto an IX turbo? What about the waterlines and waste gate actuator? I don't mind modifying the stuff if I have too.
Thanks!
Old Mar 24, 2010 | 03:52 PM
BlackonBlack2's Avatar
no not that i know off... all has to be changed to IX stuff...
Old Mar 24, 2010 | 04:01 PM
badev0's Avatar
thanks. is there anyone that can confirm this?
Old Mar 24, 2010 | 04:06 PM
AWDBus's Avatar
From what I have read, the water line can be bent to fit. I still have not found out about the output pipe.
Old Mar 24, 2010 | 04:47 PM
EvoJoeIX's Avatar
they make a kit to run a 9 turbo on an 8... you need that
Old Mar 24, 2010 | 04:51 PM
badev0's Avatar
Yeah, I know. It doesn't include a waste gate actuator. My turbo didn't come with one. Anyone know if the VIII WGA works on an IX?
Old Mar 24, 2010 | 04:57 PM
EvoJoeIX's Avatar
yes the wastegate will work
Old Mar 24, 2010 | 04:58 PM
evo unknown's Avatar
No, you need an evo 9 conversion kit for evo 8s. I know FP sells them, check their website. The conversion kit should be about $100.
Yes, the wastegate actuator will work though.
Old Mar 24, 2010 | 06:15 PM
heel2toe's Avatar
I believe the wastegate between the two turbos is actually a little different.
Old Mar 24, 2010 | 07:07 PM
badev0's Avatar
I see. Is there anyone with an VIII WGA on their IX turbo?
donaudi
31
Aug 21, 2010 12:56 AM
SEEnoEVO
Sep 9, 2008 06:27 AM
Celica2EVO
Oct 30, 2007 07:14 AM
Evo IX MR
21
May 22, 2007 01:42 PM
Stinkapuss
45
May 17, 2006 09:50 PM
