Upgrading 64mm to 84mm FP red, questions
I've recently picked up a evo with a 64mm FP red, I talked with FP and I can upgrade to the 84mm surge port housing for relativley cheap. I know it's gonna require a new tune, but will it be safe to drive around for awhile until I get a tune? Or should I wait till I have the funds for both at the same time?
Thanks in advance
Thanks in advance
well idk if its the same but for my supra im about to switch from a tt to a single and the guys over at sound performance told me i should just wait to be able to afford both things at once even tho it would be fine drive with the new turbo on.
Will do, Hopefully a local tuner will help out. If not I might be heading to AMS. I'll keep everyone posted. I currently make 390whp at 26psi on 64mm housing.
Correct. The 84mm housing was not made you flow more than the 64mm. However there are mods you can do to make it flow better, however its main purpuse is to minimize surge.
I have the 84mm housing and love it. Great mod to improve driveability. Not sure if it is going to hurt me on power but once I put my 2.4 in I will be going for the FP Red record. I didn't get a before and after when I switched either...
Mikey
Mikey
Mikey
Mikey
