4th pops out randomly WTF...
Old May 1, 2010 | 09:24 AM
gallas's Avatar
Originally Posted by dyezak
I used to rebuild these trannys, usually popping out of gear is a bent shift fork, the gears aren't engaging properly, and when power is applied they seperate and you pop out of gear. You don't have to bend a shift fork much for this to happen, .05" is enough. Usually a bent shift fork is caused by people getting lockout issues from a heavy clutch disk (stock type full face disk). The person gets lockout, tries to force it in gear, bends the fork. Problem is when you put full power on a partially engaged gear you are reducing your contact surface and have the possibility of stripping gears. One of my good friends did this with about 350whp, so it's not big HP cars that have to worry, it's all cars.
Shift forks are cheap (roughly $100-125 new). Buy a new 3/4 shift fork and drop it in, along with either adjusting your current clutch to get rid of lockout, or a lighter clutch disk. Shift forks, clutch and Redline (heavy) shockproof will have you fixed up. Since you already dissasembled your tranny I assume this will be no problem for you.
Oh, and if you have the cash, get a twin disk to eliminate your lockout.
yeah i took the car to the dealer to do a test drive and let me know what they think. and they want to rebuild the entire trany or replace it and put a all new clutch set up in their. i had my flywheel resurfaced and pressure plate cuz it was horribly resurfaced by the dealer and was extremely uneven... do you know the maximum amount of step you allowed to have b4 u have to replace the pressure plate and flywheel? the flywheel is stock and has been resurfaced a total of two times and pressure plate one time.
Old May 6, 2010 | 02:02 PM
dyezak's Avatar
I don't remember the maximum values, but two times isn't bad. I resurfaced 5 and 6 times on some flywheels. It should be fine.
Old May 7, 2010 | 03:24 PM
gallas's Avatar
hmm well i just drove it today and drove great for awhile. i think i mite have a bad master slave cuz when i come to a stop with it in gear and the clutch pressed all the way to the floor the rpms drop and act like its gona stall for a sec. how do you test if you master slave is bad? it moves back and forworth but i never get to see it while im driving and having the problem lol...
rpm_ruffryders
Lancer Engine Tech
603
Mar 3, 2020 07:04 AM
BEISSEN
16
Jun 26, 2011 05:36 PM
mac214
Mar 18, 2009 10:02 PM
VRamirez2004
16
Oct 6, 2008 11:18 PM
plokivos
Jan 21, 2005 05:18 PM
