Help Backfire
Old Apr 22, 2010 | 08:01 PM
widge's Avatar
The fuel pump is brand new.
The more i read this thread and check things its coming back to a boost leak, im going to remove the front bumper and all the stone tray tonight/tomorrow and have a really good look around.
What would happen if the AFM has **** itself?
Old Apr 23, 2010 | 04:27 AM
hotrod2448's Avatar
Also keep in mind the hose blowing off at an attachment point isn't the only failure mode here. It could be a rubber section split somewhere as well.
Refresh my memory on what the AFM is. MAF?
Old Apr 23, 2010 | 08:43 AM
andrewzaragoza's Avatar
just like what they are saying do a boost leak test. you will find leaks that you wouldn't see.
Old Apr 23, 2010 | 08:59 AM
chin0's Avatar
or just take it to a local tuner have them do it and pay out the a$s. its got to be the pipes, shyt popped off on me on the high twice and i got hit by a truck when it happened so thats how i know its got to be it or a really really bad boost leak!
Old Apr 23, 2010 | 03:06 PM
widge's Avatar
I checked the pipes last night cant find anything, i think im going to try do a leak test today with my compressor
Old Apr 23, 2010 | 03:07 PM
apagan01's Avatar
ic pipe popped, plugs foulled, \
just start troubleshoting the simple stuff 1st
Old Apr 23, 2010 | 06:12 PM
widge's Avatar
Ok i dont believe there is any leaks.
Ive tried new plugs and still same thing starts with a little accel runs rough for a second and back fires.
On further checking of the timing belt it seems as though the Inlet and Exhaust are half a tooth forward, does this mean it has skipped 1 tooth forward?
Old Apr 23, 2010 | 06:48 PM
widge's Avatar
Ok im going to check, it may have skipped a full tooth on the harmo balancer making it show half tooth on the cams
Old Apr 23, 2010 | 07:30 PM
widge's Avatar
Ok i double check timing with the AC belt off bottom on top dead and the cams line up exactly so back to the drawing board
Old Apr 23, 2010 | 08:07 PM
widge's Avatar
Guys here is a video of what its doing im out of options right now.
http://www.youtube.com/watch?v=40T1BEGox48
This is what its supposed to be like
http://www.youtube.com/watch?v=jDApDiA8WNg
Thanks
Old Apr 23, 2010 | 09:01 PM
widge's Avatar
I just checked coil packs and there all sparking fine, tried another set of plugs too
Old Apr 23, 2010 | 10:47 PM
widge's Avatar
Heres a log of what its doing, if it means anything or if there is something else i need to log?
Its in a zip file because the forum wont let me upload csv files
File Type: zip
Old Apr 23, 2010 | 11:01 PM
High_PSI's Avatar
Jumped timing?
Old Apr 23, 2010 | 11:32 PM
widge's Avatar
Thats exactly what i thought but i put the Crank Pully on the T and the 2 cam pullys line up to there marks on the rocker cover
Old Apr 23, 2010 | 11:51 PM
widge's Avatar
Im really out of ideas right now, i Disconnected the Crank Sensor and the car wont start at all, i disconnected the cam sensor and the car starts for a sec then stalls.
If both plugged in it sounds like the video i attached, could it be AFM/MAF?
