Help Backfire
Old Apr 24, 2010 | 10:53 PM
  #46
20austin08's Avatar
aww. My fault didnt see you were in Australia. I dont know how the hardware game is there. Before trying anything else extreme I would definately just try to find the parts to make a BL tester. My family owns a hardware store so I took advantage of the supplies. Sorry I can't be of more help i'm not 100% sure about the cam sensors.
Old Apr 24, 2010 | 11:12 PM
  #47
widge's Avatar
I tried to start the car with the cam angle sensor unplugged, this made no difference, i would think if it was working and i unplugged it things would get worse?
I really want to do a BL test but i think im going to have to fab something up with alloy
Old Apr 25, 2010 | 01:30 AM
  #48
widge's Avatar
Changed the CAS still same issue
Old Apr 25, 2010 | 05:38 AM
  #49
cfdfireman1's Avatar
pull the
Originally Posted by widge
I went to bunnings, they had nothing there.
The car wont start at all now, i have a few people leaning towards a dead Cam Angle Sensor, i have a mate with an Evo 5 are they the same sensor?
plugs they're probably wet by now.
Old Apr 25, 2010 | 07:45 AM
  #50
Evoryder's Avatar
Get a real code scanner. If you toasted your CAS your codes should P0113 and one for the CAS.
You don't have major hardware store where you live? Here's another thread on what's needed. I find it hard to believe you couldn't source...
https://www.evolutionm.net/forums/ev...er-5-02-a.html
Old Apr 25, 2010 | 07:47 AM
  #51
Evoryder's Avatar
Also does the car crank but not catch or just clicks?
Old Apr 25, 2010 | 07:53 AM
  #52
Evoryder's Avatar
Crank ANgle Sensor
Old Apr 25, 2010 | 08:59 AM
  #53
High_PSI's Avatar
What a compelling mystery! I am totally stumped. Maybe it needs gas
Old Apr 25, 2010 | 05:10 PM
  #54
widge's Avatar
LOL i wish it just needed fuel.
It could be crank angle sensor its really the only thing left
Old Apr 25, 2010 | 05:26 PM
  #55
Evoryder's Avatar
So did you pull the codes yet? And don't day you used Evoscan
Old Apr 25, 2010 | 07:37 PM
  #56
widge's Avatar
Not yet im trying to get a hold of my mate who owns a mechanic shop and he has a Scan Tool a proper one.
Old Apr 25, 2010 | 08:47 PM
  #57
widge's Avatar
so i have been unable to get the car to start for a day or so, and re-checked spark, 2 and 3 are getting spark and 1 and 4 arent.
Changed over the coil packs and its still the same 1 and 4 dont spark.
Still trying to get a scan tool any suggestions? Crank Sensor?
Old Apr 25, 2010 | 09:11 PM
  #58
widge's Avatar
Going out now to check if the Balance Shaft Belt has snapped which i have read will damage the crank sensor causing the issue im having
Old Apr 25, 2010 | 11:13 PM
  #59
widge's Avatar
Can someone give me a hand by logging there car with Evoscan and log the Crank Signal, when i log the crank signal from my car the value doesnt change from 0, i believe this value should be changing between 0 and 1
Old Apr 26, 2010 | 04:06 AM
  #60
widge's Avatar
https://www.evolutionm.net/forums/ev...5-p0340-2.html
https://www.evolutionm.net/forums/ev...ad-dead-3.html
https://www.evolutionm.net/forums/ev...t-start-3.html
These threads show the issues im having im going to try a new Crank Angle Sensor, consider my car doesnt get spark on 1 and 2 anymore
