Help Backfire
Old Apr 22, 2010 | 06:24 AM
widge's Avatar
Help Backfire
Hey Guys,
Tonight i done a second gear pull into 3rd, when it went into 3rd it backfired and started to run like **** and stalled.
Now when i try crank it starts with a little throttle but runs rough backfires and stalls.
WTF??
Any suggestions, i did a quick check of the timing belt and it looks to be fine, maybe a half tooth out but was a quick check and it cant skip a half tooth.
Suggestions please!!!
Old Apr 22, 2010 | 06:26 AM
hotrod2448's Avatar
Did you blow off an IC pipe? Maybe the original 'back fire" was the sound of the hose popping off.
JonahEVO's Avatar
Check your spark plug to see if it's foul.
Old Apr 22, 2010 | 06:38 AM
gsrboi80's Avatar
This would be my suggestion as well
Old Apr 22, 2010 | 06:43 AM
cfdfireman1's Avatar
boost hose is off
Old Apr 22, 2010 | 10:28 AM
06GraphiteEvoIX's Avatar
that is exactly what happened ill almost put money on it... intercooler pipe after the turbo is a common place for me until i put T-bolt clamps on them... damn those things go on tight... my buddy crushed his piping... haha idiot!
Old Apr 22, 2010 | 02:53 PM
widge's Avatar
Will check this out this morning thanks guys
Old Apr 22, 2010 | 03:42 PM
widge's Avatar
Intercooler pipes seem to be on nice and tight, hmmmmm any more suggestions?
Im going to do a comp test right now will post the results
Old Apr 22, 2010 | 04:43 PM
widge's Avatar
Just done a comp test and its 175psi across all 4 no variation what so ever
Old Apr 22, 2010 | 04:49 PM
kanyonkid's Avatar
not to sound like u dont know what ur doing, but check the pipes again, my bro called me while he was stuck on the freeway, i told him his ic pipe popped off, he checked and told me it was all good, he got towed home, i told him to check again, and he found it.. if its still good, do a boost leak test and check the coils
Old Apr 22, 2010 | 05:59 PM
FooM Anchoo's Avatar
When I had a major boost leak, it started and idled just fine. Only fell on its face as soon as I gave it any gas whatsoever
Old Apr 22, 2010 | 06:10 PM
widge's Avatar
I checked spark and it seems to spark fine, i put new plugs in and just made the backfire louder.
Ill check the cooler pipes again and im going to buy a new timing belt and replace that just to be sure
Old Apr 22, 2010 | 06:30 PM
EvoVan's Avatar
Yup, sounds like the pipes
Old Apr 22, 2010 | 06:34 PM
06redrocket's Avatar
Hmm bad fuel pump or injector??
Old Apr 22, 2010 | 06:47 PM
try again
you checked all of these clamps? do a boost leak test my friend. classic hose off
