when to change timing belts
Old Apr 22, 2010 | 11:48 AM
anton406's Avatar
sorry for the noob question guys, but when do you know when to change your timing belts and other belts in your evo? im at 14k kms now with light mods only, i want to find out as a precautionary measure.
thanks in advance!
Old Apr 22, 2010 | 11:50 AM
dan628's Avatar
read the manual, it should be around 60,000 mile for the timing belt. FYI there is only 1.
Old Apr 22, 2010 | 11:52 AM
anton406's Avatar
ok, thanks for the quick reply!
Old Apr 22, 2010 | 11:59 AM
grillpt's Avatar
Thats not entirely true...
When you change out your timing belt you should also change the balance shaft belts (now I forget if there more than one of those). Also, while your in there you should do the waterpump and all the tensioners and such. Your belt for your accessories (alternator and such) should be done every 30k per the manual but mine was good till about 45k, as long as its not cracking your good.
Old Apr 22, 2010 | 01:21 PM
Berts24's Avatar
^ this
Old Apr 22, 2010 | 02:00 PM
Bobster22388's Avatar
While doing this, you might as well do your 60k service on the car too; change tranny, transfer case, and rear diff oils. (Unless done previously)
Old Apr 22, 2010 | 02:15 PM
chaotichoax's Avatar
https://www.evolutionm.net/forums/ev...uantities.html
it's a sticky in this section for heavens sake
search first
closed...
turbotalawd
Nov 20, 2015 12:13 PM
ralliart 04 21
Aug 24, 2008 03:09 PM
MasterAK
Lancer Engine Tech
Feb 8, 2008 11:02 AM
rhyzin
Lancer Engine Tech
26
Dec 23, 2005 01:02 PM
