My FP Black numbers
Old May 1, 2010 | 07:25 PM
  #91
wizzo 8's Avatar
Also forgot to mention I'm running out of 4th gear as I'm crossing the traps. 7800 rpm
Old Jun 27, 2010 | 07:12 PM
  #92
wizzo 8's Avatar
I went to the track Friday and only got 2 solid passes in until my clutch started slipping. My best was 11.6@122 with a 1.7 60ft. My best mph was 125. It was also 82 degrees out. I only got a total of 8 passes with my new exedy twin that I installed in the fall. I was very upset. Then I got home and found my clutch fork stopper just needed to be adjusted out. It was preventing the clutch from fully engaging. Its holding the power again but im sure I caused some premature wear on the clutch because of this happening. So if you have one of these stoppers be sure to check the adjustment on it because as the clutch wears the stopper will need adjustment. Im going back July 10th weather permitting.
Old Jun 27, 2010 | 07:49 PM
  #93
garcias2k's Avatar
Good run man and great #'s, I hope to install a black in the near future but on a build 2.0
Old Jun 28, 2010 | 07:09 AM
  #94
Creamo3's Avatar
Your times will continue to drop, I have a feeling you'll hit low 11's our next time out. I'll datalog your runs to see if anything funky is happening throughout the pull that could be affecting your power.
Old Jun 28, 2010 | 10:12 AM
  #95
wizzo 8's Avatar
Cool. Thanks
Old Jun 28, 2010 | 11:22 AM
  #96
italianevo88's Avatar
That must be quite the road warrior with 508hp, watch out for that stock bottom end!
Old Jun 28, 2010 | 11:41 AM
  #97
wizzo 8's Avatar
Its fun especially on the highyway. I'm aware of the bottom end and am saving for it now
Old Jun 28, 2010 | 01:39 PM
  #98
tigerkill2007's Avatar
Seems like ur car is doing good and running strong and nice numbers
Old Jun 28, 2010 | 05:11 PM
  #99
almostevo's Avatar
nice!
eisnikesb
Dec 7, 2016 08:46 AM
yellaevo
Nov 23, 2011 11:53 AM
derekste
Evo X Dyno Results
16
Feb 22, 2011 11:50 AM
bbyevo8u
39
Nov 15, 2009 07:51 AM
MrEvo2nv
15
Dec 3, 2008 01:01 PM
