Apexi TT - how to change time to shutdown?
I haven't had to adjust mine in years and I can't figure out how to do it. I know there's just the one knob with four directions on the right, but holding it in any direction hasn't gotten me to where you adjust how long the car runs for.
I looked on the Apexi website for a phone number or instruction manual but couldn't find an answer anywhere.
Can anyone help?
Can anyone help?
1 Post
Here ya go
http://www.apexi-usa.com/content/pdf5492.pdf
In-case the above one doesn't work correctly:
http://www.japrace.com/images/instru...Auto-Timer.pdf
-Bink
-Bink
I was doing it right then. I can hold the knob to the right for 10 seconds and get nothing. I can adjust it once it's in its countdown, but it obviously doesn't stay at that set time.
I edited the post on you I still can't get it to work. When I have it on the Timer setting and hold it to the right nothing happens. If I hold left it will say "Off" and I can hold it to the right from there to turn it back on, so I know the knob works going to the right...I just can't access the settings menu.
1 Post
I think he's right. You either have to change it while the cars ignition is on or while the car is running. I believe you change it while the ignition is on.
I have the same turbo timer - I would check it for you, but my car is a bunch of pieces and won't be back together for another 2 weeks.
-Bink
-Bink
Buschur_TSI
Apr 2, 2010 02:16 PM
