new clutch in, but hard to get into gear
Old Apr 29, 2010 | 02:51 PM
amsevokid's Avatar
hey ppl, today i finally got my evo back from the dealer, and now with a brand new stock clutch in it, but when im ideling its hard to go through the gears, any ideas or is it normal. i searched all the threads so please no flaming, just help me please
thank you all
-Chris
Old Apr 29, 2010 | 02:54 PM
Ryan.Kauz's Avatar
My car is hard to put in gear or the car must be in gear before I start it?
This is very common when the clutch is not releasing. Most often while having the trans rebuilt the clutch is replaced. Installing an upgraded clutch requires more clutch pedal travel and needs to be readjusted and worn parts replaced. We recommend a new clutch fork, pivot ball, OEM or ACT throwout bearing and a braided stainless clutch line.
http://www.sheptrans.com/faqs/index.htm
Thats the best I can do for you, not knowing how to install a clutch myself. You will have to gleen whatever info you can and apply that to your new clutch issue..... But honestly if a dealership did it, they can re-do it, and re-do it correctly, and for free.
Old Apr 29, 2010 | 02:58 PM
kwanza's Avatar
Did you already try to adjust the clutch pedal?
Old Apr 29, 2010 | 04:26 PM
Bobster22388's Avatar
Does sound a lot like you need to have your clutch pedal adjusted. Take it back to the dealer and have them adjust it for you, you should only have about 1" of play max. before it starts to engage the clutch.
Old Apr 29, 2010 | 04:56 PM
amsevokid's Avatar
im going to adjust it myself bc i forgot about it but ill let everyone know the update.
Old Apr 29, 2010 | 05:45 PM
S6devil's Avatar
hopefully it just needs an adjustment... however its not unheard of for a mitsu dealer to have no idea how to change a clucth on an evo... last time i was at a tuner shop, and they took apart the tranny after a dealer oem clutch install, every surface was scratched and clawed - gashes in the metal, where they were apparently forcing everything together, when nothing fit...
FX11
31
Feb 12, 2019 08:54 PM
kaonashi
12
Nov 26, 2013 07:11 PM
anasyakoub
Oct 27, 2012 11:59 PM
owenxguo
21
Nov 9, 2007 11:15 PM
hacellular
15
Mar 24, 2007 08:18 AM
