New clutch install problem
Old Oct 21, 2012 | 04:03 AM
anasyakoub's Avatar
Hi
I've installed spec 3+ clutch kit in a workshop when I went to take the car the first gear won't go into first or second or any, while its off the gear moves good but while engine is running its very hard to put in the first gear I have to push it very hard many times
Any one has this issue before and what is the solution ?
Old Oct 22, 2012 | 01:01 PM
jyamona's Avatar
sub'd for a solution. GL
Old Oct 22, 2012 | 01:46 PM
05OrangeSS's Avatar
pressure plate not disengaging? if on a lift do the wheels spin while its in neutral and the car is running?
Old Oct 22, 2012 | 01:51 PM
SOUL STEALER's Avatar
Could possibly be binding of the shifter cables. I'd double check that the bushings are smooth in operation. Next I'd check the clutch hydraulics. Have you looked through the port at the clutch? Notice antthing? How does the pedal feel? After that I think you might have to take it back apart. Good luck
Old Oct 22, 2012 | 02:06 PM
2004EvoVIII's Avatar
I'm having this issue too, or I should say I HAD this issue and now my car is torn apart and I will be doing a clutch again. I've noticed that when I look up through the peep hole everything is working perfectly. The cable are all good and I have full pedal as well. I'm thinking one of the disc springs popped off. I've had this clutch on for 9k miles and everything else is working and I have no leaks or anything.
When I actually get the trans apart I'll let you know what I find. It won't be until early november though. If you find anything please let me know as well!
Old Oct 26, 2012 | 11:13 AM
anasyakoub's Avatar
Yesterday Ive did a bleeding but no gain then I've returned the OEM horizontal bushing and the shifter was smooth as stock And my smile was twenty inches , today morning its became hard again,I'm really confused now
Old Oct 26, 2012 | 08:35 PM
The Unknown's Avatar
Before my car was destroyed I was running the following;
Spec 3+ (not even 2k miles)
AMS CMS
Findanza 9lb Flywheel
I had minor issues where sometimes it would take off smooth...another time it would almost stall... or Id look like a noob and "practically" launch the ***** haha. I didnt have any trouble getting into gear per say, but the engagement point felt different almost every time. I could never figure it out because it was so damn random. I really loved the set up because when it wasnt being gay it worked flawless and felt like OEM. I don't really know anyone else using SPEC 3+ , so its interesting that you were having the same type of issues.
Then again I had a massive fuel system and everything else under the sun so that def "could" have added to take off/low speed issue. I know people hate lightweight flywheels but honestly I didnt notice any "huge" difference when I had the car idling correctly. (incase that issue gets brought up)
Old Oct 27, 2012 | 11:59 PM
anasyakoub's Avatar
AMS CMS
I've the same engagement issue on 1,3,5 gears
Yesterday I've moved the parts above the gear which has bushings and then the car was good but a one hour of driving it become **** .
millsyy17
17
Sep 5, 2011 12:22 PM
shrty10135
11
Aug 4, 2010 05:32 PM
def1
11
Oct 26, 2008 01:18 PM
oogieboogie
15
Jul 7, 2005 05:36 PM
PHILLY EVO
Jul 27, 2004 12:10 PM
