Where to find aluminum roof?
Old May 2, 2010 | 05:37 PM
EVODreams's Avatar
Anyone out there actually replaced their roof with an aluminum one? Where did you get it from and how much was it? Might just patch the hole for the sunroof and call it a day, but would really rather have an MR Roof.
Old May 2, 2010 | 05:38 PM
ak47po's Avatar
Get a carbon fiber roof.
Old May 2, 2010 | 05:40 PM
19DB794's Avatar
or find someone that crashed their MR and is willing to part with the roof skin. I think its held in with rivets so it shouldn't be too hard to remove.
Old May 2, 2010 | 05:43 PM
scarface2jz's Avatar
^^^^ this
the MR roof is 17lbs
the carbon roof is 15lbs
only 2 lbs, but you'll probably end up paying a pretty penny and waiting a while for the MR roof, since they're not really a common part, but for about $1200 you can get the carbon roof... i wouldn't patch the SSL roof cause it'll still weighs a good amount, and will cost a good amount to do also...
good luck
windshield and rear window gotta come out to change it, and thats no easy task...
Old May 2, 2010 | 05:44 PM
repost
Old May 2, 2010 | 06:32 PM
monkey_187's Avatar
ask this guy
https://www.evolutionm.net/forums/sa...evo-ix-mr.html
Old May 3, 2010 | 07:51 AM
EVODreams's Avatar
^^^ shot him a PM. Good Find! I actually think a new MR roof is under $1k. Does anyone know weight of the stock steel roof w/o a sunroof vs the MR roof?
Old May 3, 2010 | 08:04 AM
ak47po's Avatar
An aluminum roof won't be easy to install,from the factory they get riveted on.
Old May 3, 2010 | 10:18 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I bet it would be cheaper to sell your current Evo and get one with the roof you want.
Old May 3, 2010 | 10:32 AM
YAMAHArYder's Avatar
Just go to the gym.
Old May 3, 2010 | 11:40 AM
Bignel00's Avatar
good luck man. just get a rivet drill bit. post pics !
Old May 3, 2010 | 11:50 AM
nemsin's Avatar
Nearly any bodyshop will be able to access an online database to find used parts (often from crashed vehicles). They should be able to find you an MR roof no problem.
Old May 3, 2010 | 12:51 PM
gsrboi80's Avatar
Just as an FYI you can use a IX RS or SE roof as well
Old May 3, 2010 | 01:48 PM
ODUB's Avatar
no chance. a new hood is over $1400, front bumper is like $1000. no way the roof is under $1000.
Old May 3, 2010 | 05:41 PM
e\/olution's Avatar
convertable ftw
