Check Your PCV.
Check Your PCV.
I have seen posts on here about the pcv but no good write ups on replacing it, or even pics of where its at. Its a relatively simple procedure, but maybe not for some noobies. Mine recently went bad so when replacing it I decided to take some pics to help someone out in the future. I replaced mine and now car is running great again.
this is the part number and what it looks like.
this is where its located. on the back of the valve cover. To remove the hose, use some pliers to pull the two ends of the hose clamp together to slide it back. carefully pull the hose off and use a 15mm wrench or thinwall deep socket to carefully unscrew the pcv valve. You may need to hold the other end,with some pliers, where the pcv screws on the valve cover, to keep it from moving.
TommiM
May 22, 2012 10:58 PM
TommiM
Nov 28, 2009 10:20 PM
