Misfiring but not throwing a code????
Old Mar 27, 2011 | 10:43 PM
jhkim45's Avatar
gap and plugs are probably your best bet
Old Mar 28, 2011 | 10:50 AM
jackbenimbo's Avatar
the more and more i look into it, if not the plugs, im thinking its the coils due to an issue i went thru myself
Old Mar 28, 2011 | 11:46 AM
any updates btw?
Old Mar 28, 2011 | 02:01 PM
kwanza's Avatar
Did you check the coil pack? The way i tested it was by swapping it out with another. If you have a friend with an evo, pull it off and give it a try. It is best to test one, and then check the other testing it one at a time.
When my coil pack went bad, it was just failing at high boost, it would pull timing and EGT's would go sky high. Under low or moderate boost, it ran just fine.
Something else i learned is that a bad coil pack will not throw a check engine light.
Saint47
Feb 23, 2017 11:42 AM
TLeid91
Apr 4, 2016 07:43 AM
Ztevo93
Lancer Troubleshooting
Jan 12, 2015 11:34 PM
bjstrick
13
Jul 11, 2012 05:14 AM
jj_008
15
May 28, 2006 01:24 PM
