noisy fuel pump
Old May 28, 2010 | 10:48 AM
turbotalawd's Avatar
I love that walbro whine. Music to my ears.
Old May 28, 2010 | 10:57 AM
tim85851's Avatar
yup!
same here. but how do you tell if the walbro is gonna die?
Old May 28, 2010 | 01:19 PM
AutOtaku's Avatar
Originally Posted by tim85851
yup!
+1 I would like to know too.. I plan to get one but would it fail in high temperature. Say on a hot day on a track or daily commute? I live in SoCal right now. The weather isn't so bad but I know it gets pretty hot in some of the areas Plus 90% sun weekly on a black evo. hmm...
Old May 28, 2010 | 02:52 PM
EvoJoeIX's Avatar
the hotter it is outside, the louder the fuel pump will whine. also i wouldnt run the tank below 1/4 tank when its hot out since it makes the pump run hotter and could cause it to fail after a while. the fuel is what cools these down
Old Jun 1, 2010 | 01:07 PM
SLO-EVO's Avatar
Originally Posted by wizechef
how long after they start to whine do they die out? Ive only started to hear mine whine since it got hot out... Is that happening because of the heat?
thanx
well i have had mine in for 3 years give or take, and it hasnt died yet. the whine just lets me know everything is in working order.
Old Jun 1, 2010 | 01:12 PM
skyblas's Avatar
try getting other brand
i heard that the bosch fuel pump doesnt make as much noise as walbro
but they cost more
Old Jun 1, 2010 | 01:17 PM
Still_Spinnin's Avatar
Originally Posted by *constant_boost
Mine sounds like it isnt even in my tank...
Maybe it's not.
Mine is also really loud. Walbaros whine. Sometimes it means they are on their way out, and then sometimes you just have a loud pump.
Old Jun 1, 2010 | 01:26 PM
05evoGSR's Avatar
i only hear mine whine when i am almost on E, it sounds like a barrel of bees.
Old Jun 1, 2010 | 01:41 PM
MR. EVO MR's Avatar
Going on two years and I never heard mine yet single pump.
Maybe you have a dual pump?
Old Jun 1, 2010 | 03:59 PM
ssg_petty_210's Avatar
Mine does to, but that is because it is an aftermarket fuel pump. I will be getting a double pumper soon as I complete my build, then it will wine louder.
Old Jun 1, 2010 | 07:17 PM
My friends got his 2nd pump strapped to his strut bar, The car sounds sick priming and just idling with the pump whining, i <3 it
Old Jun 1, 2010 | 09:08 PM
JDM-Evo9MR's Avatar
Same here for me too. I've been using the walbros for some time now and that's something you won't get rid off. I can tell you though that the pump will last much longer if you keep the tank at 1/4 and above. It seems as if higher gas levels keeps it much cooler thus lowering the noise it makes. I can barely hear my pump on a full tank.
Old Jun 2, 2010 | 08:49 AM
CooleyKing's Avatar
^its just good practice to keep the car above 1/4 tank. the pump will run cooler and it will keep you from leaning out when the fuel is splashing around. Most tuners say not to build boost under 1/4 tank for that reason.
Old Jun 2, 2010 | 01:16 PM
MR. EVO MR's Avatar
good point
butters149
Feb 4, 2014 09:54 PM
GsrJake
Nov 18, 2012 10:18 PM
thrlskr
Aug 24, 2012 03:01 PM
RalliartMD_PR
Jul 3, 2011 02:48 PM
batty
Jun 26, 2010 06:04 PM
