Idle issue
Old May 19, 2010 | 06:19 PM
thedru13's Avatar
Idle issue
This just started. When i drove and get teh car over 3k. When I slow down to a stop and go into neutral the cars stays at 2800 rpms. I have to tap the gas to get it to go back down. Anythoughts? I have a custom tune ETS LICP Works TR340 kit.
Old May 19, 2010 | 06:56 PM
heavens turbo's Avatar
i had a whole sh!tload of idle problems when i cleaned my throttle body. it would do the same thing yours would do, but it would hunt and almost die also. i reset the computer, but it didn't get better until 200 miles later when it finally compensated. by then i ordered a boomba. check your tps and make sure the voltage is ok and adjusted correctly. it could also be a leak, (vaccuum or unmeterd air), or the iac motor. search "idle" and some guy has a thread on how to reset the idle. you can try that too. good luck.
Old May 19, 2010 | 07:08 PM
thedru13's Avatar
Thanks!!! ITs weird just out of the blue. Tonight. the only things I have changed is the addition of a LICP and MBC. ONly thing I can think of at the moment is I didn't cap one of teh nipple off the stock boost solenoid. I also have an upgraded throttle body.. This is just odd that its just started..
Old May 19, 2010 | 07:50 PM
dreyfus14's Avatar
Be sure the throttle cable isn't sticking. Move the throttle by hand and be sure the cable doesn't catch....if you have to assist the throttle to close the last bit, then that is what is causing the high idle....then pin point cable or TB problem
Old May 19, 2010 | 07:52 PM
detroit pistins's Avatar
i heard that on the 9's there is a tsb (tech service bulletin) that they encounter Throttle Hang issues, so that might be what ur experiencing, ur throttle cable is not retracting where its suppose to. check with the dealer!
Old May 19, 2010 | 07:56 PM
here u go, check these out.
https://www.evolutionm.net/forums/ec...per-table.html
Old May 20, 2010 | 12:14 AM
termite_one's Avatar
Originally Posted by detroit pistins
Thats an awesome thread, info I have been wondering about for a long time!!! thx.
jmsrt4
23
Jan 30, 2014 02:10 PM
Gsr08
Aug 15, 2013 05:36 PM
Drooke
10
Jan 4, 2013 03:29 AM
alpix715
Aug 30, 2010 03:13 AM
EVOlutioner
Jun 24, 2009 06:03 AM
