wastegate being pushed open?
Old May 28, 2010 | 02:56 PM
EvoJoeIX's Avatar
so when i try to do a pull at low rpms, high load (like 4th gear starting at about 2500rpms) the car just hit 15 pounds and stays there. it sounds to me that the wastegate is being pushed opened by all the exhaust flow. i can here exhaust coming out the dump tube.
has anyone had this problem?
would a stiffer actuator fix this?
Old May 28, 2010 | 04:50 PM
twista's Avatar
Try checking the preload on your actuator arm.
Old May 28, 2010 | 06:03 PM
Steed77's Avatar
Check your boost controller and do a boost leak test. I would think your issue would surface here.
Old May 28, 2010 | 08:58 PM
boostedwrx's Avatar
What o2 dump are you using? Gasket?
Old May 28, 2010 | 10:15 PM
EvoJoeIX's Avatar
how do i adjust preload?
im thinking the actuator is just worn out since this problem happend out of nowhere.
im 100% sure its no boost leak and my MBC is perfectly fine. that was the first thing i checked
im using a jm fab o2 dump and their gasket. everything is pretty new, so i dont think that is the problem
Old May 29, 2010 | 12:17 AM
twista's Avatar
There are a few videos at FP to help a bit. Basically you can lengthen or shorten the actuator rod by undoing the lock nut and winding it out (after disconnecting it from the wastegate) The wastgate should be pushed firmly closed. I'm sure theres further info on the forum
http://store.forcedperformance.net/m...de=Turbo-Parts
Old May 29, 2010 | 08:04 AM
EvoJoeIX's Avatar
ill adjust the preload today and see if that helps
Old May 29, 2010 | 09:04 AM
boostedwrx's Avatar
Cool - that should work fine. If you were using the stock gasket with that o2 dump I could see how you could be leaking exhaust right out the dump tube.
I'll be adjusting the actuator on my FP Black today and will be following the videos on the FP site (like the link Twista posted above)
standard preload: http://store.forcedperformance.net/m...td-setting.mpg
high preload: http://store.forcedperformance.net/m...gh-setting.mpg
NealeSNZ
Apr 3, 2016 12:34 AM
Bucky505
Oct 5, 2013 06:27 PM
cpunlamd
Jun 20, 2010 07:22 AM
eag36
27
Dec 9, 2009 07:06 PM
russya
Jun 23, 2008 01:44 PM
