SRS Light
Old Jun 15, 2010 | 11:12 AM
confusionisbad's Avatar
SRS Light
Was wondering if anyone had experienced the same issue I am having with my SRS Light.
About 2wks ago I put my car up on some Rhino ramps to do an oil change and change out the injector wires. I left it on the ramps over night and in the morning finished up the oil change and backed it off the ramps. After than I took it for a drive as normal an noticed my SRS light was randomly going on and off.
So with that being said the SRS goes on and off. I have noticed it will almost always go off an a normal Left/Right turn and usually driving slowly in parking lots.
Any ideas?
Thanks
Old Jun 16, 2010 | 05:53 AM
goldenEvo's Avatar
Scan the SRS system for any codes. you may have a barely broken wire somewhere.
Old Jun 16, 2010 | 08:40 PM
djikonatx's Avatar
check for ANY loose sensors. had the same problem on mine . turned out to be a faulty #2 fuse. if all fails take it to the dealership. if the srs light is on your srs system wont work .
Old Jun 17, 2010 | 12:01 PM
roadace's Avatar
I had a SRS light stay on due to a bad sensor. It was replaced at the dealer. No problems since then.
jimbo74
Lancer Troubleshooting
Sep 11, 2016 02:38 PM
epremsoft
Jan 7, 2016 06:24 AM
RedEvoxGSR
Sep 13, 2012 05:23 PM
projekt_shocker
Nov 18, 2007 08:48 PM
rcheung
May 29, 2005 10:16 AM
