Wideband just stopped working
OK, I don't know how old this gauge is but it's now constantly reading 14.7-14.9. Doesn't go anywhere outside those numbers. I tried replacing the sensor and now it goes down to 14.6 but nothing lower. Could it but the gauge itself? I don't want to buy a new gauge after finding out how much one actually cost (got mine with the car)... Worked fine a few weeks ago.
I have an AEM wideband with a Bosch sensor.
It recalibrates itself every time I turn it on (it's hooked up so that it turns on with the headlights, I know, stupid). It was working fine before but now, it's just reading constant 14.9. I think last week, it would either work correctly or kept reading 14.9. Like it was dieing on me but how does a gauge like this die.
I run just regular (premium Shell 93 to be specific) gas.
OK, it's weird. It reads 14.6 when I give it gas and 14.9 when there's close to or no gas. So it's reading something but not fully. Again, I changed the sensor to a Bosch.
AEM should be the same process IMO, I think it's more accurate when sensor calibrate itself with ambiant air than in the exhaust .
i would unplug the sensor completely and see if it changes anything. sounds like the gauge died if you already replaced the sensor and the connections are good.
does the gauge sweep quickly between the 14.7-14.9 or does it kinda slowly bounce between them?
alfredoaal
Oct 20, 2015 12:35 PM
ezzey
Jul 19, 2012 07:41 PM
