Need help evo 9 se wont start
Old Aug 2, 2010 | 11:37 AM
  #31
deylag's Avatar
Maybe the car has no oil in it.
Old Aug 2, 2010 | 11:57 AM
  #32
D-Mon3y69's Avatar
Originally Posted by Jin-X
Just my 2 cents, is that it could also be a bad alternator too. My wife's car previously just broke down on the a freeway. When I got there, when you turn the key to on, it wont crank or anything. I did hear some kind of buzzing noise, but not like a clicking noise from the starter. Luckily I was able to jump start it and drive it home and replace the alternator and it's working like a champ now.
if it was the alternator you would be able to jump start it and it would run for awhile until it completely drained the battery again and then die. i had to jump start my old truck 3 times in order to get it home from a mile down the road.
if you check the battery then it should be your starter like everyone else said. go get it tested.
btw it could be you don't have any gas your gas light is on, i can't tell how much gas you have tho.
Old Aug 2, 2010 | 04:55 PM
  #33
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
ur car is sounding like mine have u tried turning the key quickly to try to start it, that works for me currently
Old Aug 2, 2010 | 10:30 PM
  #34
VRSF Tiago's Avatar
How did you test your battery? Have you tried jump starting it? Looking for anything else without properly testing the battery or jump starting it isn't going to get you far.
Old Aug 4, 2010 | 11:47 PM
  #35
05VIII's Avatar
well if you listen to the video he posted, it sounds like it is sending constant power to the starter. it doesnt sound like its running out of juice, it sounds like that battery is pumpin out full voltage. which leaves me to believe the battery is strong and juiced up. but then again, you never know. do like i said and hook up another car with some jumper cables, thats the fastest way to check at home. or go the extra mile and swap batteries with the other car and try cranking it. it would save you the trip to the parts store and finding out battery is good.
Old Aug 5, 2010 | 12:35 AM
  #36
VRSF Tiago's Avatar
I didn't have sound so I couldn't hear what was going on. Videos removed so I'm guessing its fixed.
Old Aug 7, 2010 | 12:36 AM
  #37
Derock2gspyder's Avatar
test battery if it checks out good its the starter!
iM.So.EvO
Sep 28, 2014 12:24 PM
32rulz
Apr 14, 2012 05:40 PM
khmerguyx
Dec 30, 2011 12:03 AM
mister thura
Dec 2, 2006 09:59 PM
cky3396
Oct 11, 2005 11:23 PM
