no more radio , clock ... fuse ?!
Old Jul 12, 2011 | 10:48 PM
hyp36rmax's Avatar
i have this issue, however when i replace the fuse in the yellow box under the hood connected to the dome light, radio, clock, it still blows... i'll check the wires on the driver side kick panel in the morning, is there any way to clean that corrosion or do i just need to re-do those wires?
Old Jul 13, 2011 | 04:25 AM
elmark44's Avatar
oh my last summer radio problem !
i replaced the fuse (7.5 if i remember) and that was doing nothing....
after i begin to search around the radio and i found a fm transmitter back to
the dash who was probably causing my blown fuse.. who happen me 2 year
after getting the car... weird thing !
for you... i think you hve to go on driver side panel to fix the fuse.. if i correctly
remember.. and i never see some corrosion can you send some pics ?!
Old Jul 13, 2011 | 02:14 PM
hyp36rmax's Avatar
I didn't see any corrosion in the wires in the driver side kick panel today and everything looked fine, i'll check the head unit as well, ill try to get some pictures while im at it also.
Oddly there are no fuses corresponding to the radio or the dome light in the cockpit fuse box...
Old Jul 13, 2011 | 03:27 PM
hyp36rmax's Avatar
Ok figured out my issue, i took the stereo out unplugged it all and it turned out to be that damn FM transmitter also...
Thanks Elmark44 for the insight!
Cody Parrott
Lancer Troubleshooting
Jul 10, 2024 08:41 AM
jzapatajr
17
Jun 2, 2020 06:44 PM
Pssst
Feb 6, 2012 06:28 AM
BornSinner
Nov 1, 2007 09:27 AM
Sr20kidD
Jul 24, 2007 03:54 PM
