Fuel Pump Assembly Wiring Diagram
Old Sep 2, 2010 | 08:41 AM
Acree's Avatar
I can't find the pin out in the service manual for stock fuel pump assembly. Can someone layout the wire color and use for each one. And also when does the fuel pump change from 5v to 12v? Is the positive fuel pump supply wire used for 5v and 12v? Or are they separate wires?
-Acree
Old Sep 2, 2010 | 01:26 PM
SuzukiDan7's Avatar
Even though I don't own an evo ,I have an evo 9 fuel pump lol.. and if I recal correctly, it has 3 wires going to it. I would assume 1 is low voltage for startup and cruising and the other is high voltage for WOT conditions. Third wire is ground obviously.
Old Sep 2, 2010 | 01:44 PM
sgounaro's Avatar
As far as I understand from the wiring diagram... There are 2 wires to the pump . The connector has more but they are used for other things.
Pin 4 and Pin 5 on the connector are used for the power to the pump ... Pin 5 is white and its the power wire and pin 5 is black and its ground.
The power wire is always the same they only thing that changes through relays is if the current flows through the resistor or not which is controlled by the ECU pins going high or low.
So if you are at idle(or low load) the current flows though the resistor limiting the voltage to the pump, otherwise it will go straight through.
A basic explanation can be found here:
http://www.roadraceengineering.com/e...elpumpinfo.htm
They explain it much better than me
SPiro
Old Sep 2, 2010 | 01:57 PM
Acree's Avatar
Through research and pouring over the IX service manual, sqounaro appears to be correct.
Now my question is, where is the resistor physically located in the car?
-Acree
Bloomie
10
Jan 28, 2024 09:31 AM
Acree
Jan 16, 2013 12:47 PM
jeandsm
Apr 20, 2011 05:25 PM
BluEVOIX
Nov 16, 2010 01:59 PM
