Fuel pump (positive) power wire?
Old Nov 11, 2010 | 12:00 PM
BluEVOIX's Avatar
Any one know which wire from the harness that plugs into the fuel pump assembly carries the positive power wire?
I'm going to be installing a boost-a-pump and need to use that power wire.
Also is there a different/better location I can cut into it from other than by the tank area?
Old Nov 11, 2010 | 12:20 PM
3vil_3VO's Avatar
Get a probe tester. Do you have one? Comes in super handy.
Old Nov 11, 2010 | 12:31 PM
BluEVOIX's Avatar
Nope, dont have one or a multimeter.
Old Nov 12, 2010 | 07:48 PM
BluEVOIX's Avatar
Any one know ?
Old Nov 14, 2010 | 07:35 PM
BluEVOIX's Avatar
Ok bought a multimeter . Seems like the thick white wire is the positive power wire . Anyone have a service manual or some sort of scamatic to confirm ?
Also where do these wires run to? Any better location in cabin rather than the pump assembly spot ?
Old Nov 15, 2010 | 10:22 PM
BluEVOIX's Avatar
I confirmed and the white 14 gauge is the positive power wire and the black 14 gauge next to it is the negative.
Boost a pump installed and running.
Just adding this info in case any one else searches, here is the answer.
Old Nov 15, 2010 | 11:39 PM
Ekoy's Avatar
I'm glad you found it out. Did you tap the wire by the fuel sending unit? What exactly is a boost a pump?
Old Nov 16, 2010 | 01:57 PM
BluEVOIX's Avatar
Yes that is where I tapped the wire.
A Kenney Bell boost-a-pump is a device that increases the input voltage towards the output. There for increasing the fuel pump voltage will increase the fuel flow capacity. Say for example a walboro 255 pump flows at 255 lph at 12 volts. Well with a boost-a-pump increasing the voltage to 17 volts, it may flow as much 300+ lph.
Old Nov 16, 2010 | 01:59 PM
Silk's Avatar
Sounds like a band aid
ridenrunwv
Jul 25, 2015 05:01 AM
caevo8
West Region
Apr 29, 2012 01:21 PM
NOMIEZVR4
Aug 7, 2011 12:26 PM
jeandsm
Apr 20, 2011 05:25 PM
awd2gen
12
Apr 9, 2010 04:23 PM
