Why so difficult
Old Sep 3, 2010 | 09:31 AM
rcheung's Avatar
Originally Posted by ZincGT
iridiums are not supposed to be gapped do to the fact that you could damage the tip. Im not saying you cant, but just be careful when you do it. Changing the gap helped you because you were blowing out the spark and the shorter gap allowed for a "stronger" spark.
If they're not supposed to be gapped I don't know how else to fix the misfire issue. If you use pliers to move the electrode up and down then use a feeler gauge to check the gap, you can safely gap iridiums.
Old Sep 3, 2010 | 09:36 AM
meckert's Avatar
Try again-- all plugs need to be checked for gap and regapped if needed. Iridiums are a little different in that you can't pry on the iridium tip to set the gap or it will break. That said you use the rt tool for the rt job and adjust the electode end to set the gap... that being the "L" shaped arm over the electrode.
Old Sep 4, 2010 | 09:27 AM
ZincGT's Avatar
From NGK:
Should I gap my Iridium Plugs?
The manufacturers say NO.
This is because most people do not know how to properly gap a spark plug, and the center electrodes on the ultra-fine iridium can easily snap if mishandled. There is no warranty for snapped center electrodes. The manufacturers say an iridium spark plug will run so much better than a traditional plug, even if it is not gapped for that motor, that they would prefer you just leave it rather than risk snapping the center electrode.
Personally, we at sparkplugs.com, gap our iridium plugs for our own vehicles (we’re rebels). If you insist on gapping your iridium plug, please refer to Proper Gapping for instruction.
pretty much exactly what i said. You are not supposed to, but you can if you do it carefully. no need for me to ''try again"
Old Sep 7, 2010 | 12:05 AM
governmule's Avatar
Well here more specifics on what I mean by studder. From a 5th pull at 3k I nail it the rpm's jump to 4300 then drop back to 3200. My boost gauge follows suite.
Old Sep 7, 2010 | 12:07 AM
VRSF Tiago's Avatar
That's a slipping clutch.
Old Sep 7, 2010 | 09:55 AM
OneEyedJack's Avatar
Bingo
Old Sep 10, 2010 | 03:13 PM
governmule's Avatar
Well it is for sure my clutch. I got a quote on a new one and install. I can't really afford to get it installed. I'm a diesel technician so I figured I would just do it myself. How much different can it be besides about 1/4 of the size. Does anybody know what all tools I need to get this done in reasonable amount of time?
Old Sep 10, 2010 | 09:54 PM
apexisilver8gsr's Avatar
hey man its prolly ur tune
Old Sep 10, 2010 | 11:32 PM
VRSF Tiago's Avatar
hey man it's prolly ur clutch....
Old Sep 13, 2010 | 03:17 PM
governmule's Avatar
Well I'll get the new clutch and put it in and while that's happening I'll get cams and a tune. Both problems solved.
Old Sep 13, 2010 | 03:23 PM
SLO-EVO's Avatar
Originally Posted by outtanowhere
Iridiums dont need to be gapped.Mistake I made.
yes they do. where do you get this information from?
Old Sep 13, 2010 | 03:25 PM
SLO-EVO's Avatar
From NGK:
so they are going to gap it to where it needs to be based on your specific setup? I dont think so. that is generally for N/A vehicles...
Old Sep 13, 2010 | 03:33 PM
kousayee's Avatar
it took me 18 hrs to change the clutch, go pay $600 for shop
Old Sep 13, 2010 | 08:19 PM
governmule's Avatar
I have access to a full garage with a lift. I just needed to know what tools I would need to get it done. I already have to sell my truck to get the clutch.
Old Sep 15, 2010 | 09:21 AM
governmule's Avatar
Book time it should only take 12 hours.
fostytou
359
Oct 23, 2025 09:54 AM
ruarctb
Lancer Troubleshooting
11
Apr 12, 2016 10:59 AM
Mcgee
Oct 11, 2012 04:50 AM
Spinsall4
Nov 26, 2007 10:43 AM
