Car won't start...But it sounds close.
Old Sep 10, 2010 | 08:37 AM
sk82712's Avatar
First off, yes I searched. I found a few threads that were close, but no cigar.
Well, the car just refuses to turn over. New starter, yes the battery is charged, yes I have spark, yes I have fuel. I'm leaning towards the MAP and MAF sensor being bad. At one point, before the car completely died, it was having trouble above 4k RPM. Apparently it would 'stutter'. I read another thread about how the Crank Position Sensor can also cause similar problems. Input?
I'm getting the following codes:
P0113: Intake Air Temperature Circuit High Input
P0069: Map sensor
And at one point the car threw a 'left bank lean' code..Not sure on the actual P code, but that's what the guy who was working on it (while i was in Afghanistan) said.
Any other input guys?
-Adam
Old Sep 10, 2010 | 09:08 PM
Bump for some Guru help for this man
Peace
Old Sep 10, 2010 | 09:18 PM
apexisilver8gsr's Avatar
compression test ! had the same problem my head gasket was blown
Old Sep 10, 2010 | 09:28 PM
Evoryder's Avatar
crankangle sensor.
Old Sep 10, 2010 | 09:43 PM
yes also check all the voltage for ur sensors
Old Sep 11, 2010 | 03:24 AM
sk82712's Avatar
Peace
I hope it's not this.
Originally Posted by Evoryder
crankangle sensor.
That's what I've read also. Thanks.
For which ones?
Thanks guys.
-Adam
Old Sep 11, 2010 | 07:50 AM
1d10t's Avatar
Blown HG won't cause a no start.
And compression would have to be really low too.
Hey guy, whats your mod list? You say you have fuel and spark... Did you pull the rail and injectors out to verify fuel? Not just fuel pressure. If infact, injectors are firing, check timing. Pull your maf and inspect it too
Could very well be you cam/crank sensor, if youre not getting fuel injected
DSMMR21
Nov 23, 2014 03:20 PM
08evo_x
Oct 2, 2014 07:38 PM
McDougal
May 16, 2013 05:24 PM
miked420
Mar 5, 2012 06:13 PM
nitz
Jan 2, 2009 02:15 PM
