Hard chatter and soft pedal
Old Sep 12, 2010 | 10:34 AM
S13 Curtis's Avatar
Ok i went to the local track and on my first pass I launched it off the 2 step (5500) came out the hole good threw it in 2nd and nothing was in second gear but went nowhere as if there wasnt anything. So I coasted down the track and checked out the car drove it around and 2nd gear works.The clutch now engages all the way at the bottom now and Chatters hard and dash shakes when putting it into gear kinda makes like a scraping sound, but once in gear it drives normal wont slip or anything. Also when you just lay your foot on the clutch pedal not pressing it in, it has a wierd vibration that was never there before. I would greatly appreciate your help and i tried to make this as detailed as possiable. Thanks
-Curtis
Old Sep 12, 2010 | 12:47 PM
S13 Curtis's Avatar
????? pressure plate????? fork???? Once in gear it drives normal.
Slave isnt leaking so shouldnt be that.
Old Sep 12, 2010 | 01:37 PM
white_evo27's Avatar
what kind of clutch????
Old Sep 12, 2010 | 01:42 PM
Chris Moore's Avatar
You probably popped the throw out bearing clip part way off. Been there, done that.
Old Sep 12, 2010 | 01:44 PM
S13 Curtis's Avatar
TTP Single disc clutch
jd888jd
May 4, 2016 04:35 PM
Pure Playaer
26
Dec 25, 2006 10:11 PM
ambystom01
Lancer Tranny/Drivetrain Tech
Mar 23, 2006 04:02 PM
bigjhoney
11
Sep 5, 2005 11:30 AM
zstryder
Jul 12, 2005 12:19 AM
