Help...CP9A/Evo 5 - No speedo
Old Sep 26, 2010 | 08:12 AM
Outlanded's Avatar
Hey Guys,
I was driving along the other day and all of a sudden lost my speed on my speedo...
I checked output from the speed sensor and its all ok, does anybody know which wire provides the dash cluster with the speed signal??
There are a number of plugs but I have no clue where to start...
Any help would be great.
Cheers
Old Sep 26, 2010 | 03:32 PM
Outlanded's Avatar
while that sounds great to have no speedo its a real pain... don't want any tickets...
ground all seems to be fine, everything else in the cluster is working perfectly... :S
does anybody have the pinouts?
Old Sep 28, 2010 | 07:34 AM
Outlanded's Avatar
bump
Old Sep 28, 2010 | 01:44 PM
S0rc3r3r's Avatar
Intermittent or non-working Speedometer
Cars affected: Ralliart UK * supplied Evos 5/6 & TME
Symptom:
The Speedometer either flickers or just does not register any speed. It is
usually only a temporary fault but can end up as permanent failure.
This can be due to a couple of reasons.
The main reason for an intermittent or totally non-working Speedometer is that the
electrical connector on the Speedometer drive gear on the gearbox can become
water logged (especially if you have washed the engine bay, never wash the engine
bay!) and is shorting out. This stops the signal reaching the Speedometer.
To cure this fault you need to open the connection, dry it out, make sure it is not
corroded and reconnect.
The second reason is due to a faulty kph to mph converter.
This is mainly a problem due to the type of converter used and this pretty much only
affects the early Ralliart cars (E5/6). The converters on these early cars consist of a
rectangular grey plastic box that is either screwed or stuck onto the engine bulkhead
(see photo, note the exact position on the bulkhead may vary). Due to vibration they
can eventually fail and stop the signal reaching the Speedometer.
The cure is to replace the converter for a later version that is mounted inline straight
on the Speedometer drive gear on the gearbox.
Approximate cost of repair:
Approx £100 to replace converter (FOC if still under
warranty)
* Ralliart UK now trading as Xtreme Autos
send me an email address i can send the photo to
Old Sep 28, 2010 | 06:00 PM
Outlanded's Avatar
Thanks for the reply.
Car has no converter as its a JDM E5 and I live in Japan! its really bizarre as It has speed signal, at the sensor, but i dont know if its getting to the cluster... you dont happen to know which wire carries the signal in to the cluster or where they split after they come through the firewall to trace it?
Any help would be appreciated.
Thanks,
Regards,
Brent
Symptom:
warranty)
Old Oct 5, 2010 | 06:09 PM
Outlanded's Avatar
bump....
anyone got any pint outs for CP9A Cluster...
Old Oct 5, 2010 | 06:20 PM
Alchem1st's Avatar
If you're certain the speed signal is making it to the cluster, then check the power with a multimeter. I have a CN9A cluster in my Mirage (CJ chassis) with no issues at all, though it looks to be an issue with CP9A clusters only according to S0rc3r3r's post. Those pinouts are somewhere on Mirageforums I know, cause that's what I used for the install in my Rage.
Old Oct 5, 2010 | 06:23 PM
Outlanded's Avatar
thanks for the reply, dont know what mirage forums by any chance? cheers
Old Oct 6, 2010 | 03:21 AM
Alchem1st's Avatar
www.mirageforums.net I'll see if I can find the thread later today. It's 6:30am and I just got home from work. I'm beat LOL.
Old Oct 6, 2010 | 04:26 AM
Outlanded's Avatar
man that would be awesome! in the mean time I will check it out! its only 825pm here in Japan! I just got home from work too..
If you know anyone who needs parts from JP let me know!
Old Oct 6, 2010 | 07:48 AM
Outlanded's Avatar
there is so so so much stuff on that forum... i found a heap of manuals etc, but nothing that I could pinpoint to the dash cluster of a CP9A
Any help would be appreciated dude.
Cheers
Old Oct 7, 2010 | 12:18 AM
Outlanded's Avatar
problem solved! severed wire where it was rubbing on a peice of metal! traced the loom and there it was!
Thank you to all who helped!
Old Oct 7, 2010 | 02:37 AM
Alchem1st's Avatar
Cool, glad you got it figured out! Hey man, not drop by on there sometime, there's alot of stuff on there relating to older Evo's and I'm sure my friends on there would love to see a real V haha.
Old Nov 11, 2011 | 11:11 AM
2002EVOBOYTME's Avatar
how did you fix it? no speed here too.. not the sensor.. or fuse
hameedosh
Oct 11, 2015 07:26 AM
jk_evo8
Jul 13, 2011 07:51 PM
pettyboy69
Dec 14, 2010 06:20 PM
gamaxer
Mar 30, 2008 01:51 PM
standbyxxx
Lancer Troubleshooting
Dec 25, 2006 08:33 AM
