Evo died on the way home.
And all fuses are ok? Check the wiring for iat sensor, I'm not sure what sensor it is but when it goes bad it cuts spark. Cam angel sensor or mayb crank angel...do a search on those and see what comes up.
This really sounds like a Fuse Problem. Check both fuse panels, Under Hood, and Under Dash. Good luck
Only other possible thing would be CAS sensor's, or IAT.
Cam sensor is next to Cams right side, Crank Sensor is behind/under the Timing Belt. IAT on stock throttle body is on the left side of manifold.
hooliganSKATE
Jul 16, 2015 06:21 AM
