Help light's
Old Oct 25, 2010 | 04:56 PM
dac001's Avatar
Help light's
didn't know were to post ithis.
it started to day at work went out for cig at 9am light were off. 11:30 lunch time lights were on... got home about 1hr later stepped out for a cig light were off.. went out side about 2 hrs later and my light were on. i have a turbo timer so i set my headlights off and my running lights on so my gauges say on when the turbo timer is counting down car shuts down then about 3/5 mins later the lights go off...like normal .... has anyone had this problem? or know what to look for... txs
Old Oct 25, 2010 | 05:22 PM
evo milk's Avatar
Wow my head hurt trying to dechipher that.
So you're saying your lights turn off and on randomly when you set your turbo timer? And you leave your light switch set on the parking lights?
Old Oct 25, 2010 | 05:30 PM
dac001's Avatar
lol sorry for that....the T-timer is set to auto so when i get out of the car it stays running so does the lights. timer stops. car shutsoff light say on for 3/5 min then the lights go off like normal. then 1 or 2 hrs later light are back on.... hope this will help...\
Just on Randomly..
Old Oct 25, 2010 | 06:30 PM
chaotichoax's Avatar
first thing you need to do is check your driver's side kick panel and see if your wiring connections are corroded/water damaged
Old Oct 25, 2010 | 06:33 PM
https://www.evolutionm.net/forums/in...s-how-fix.html
Old Oct 25, 2010 | 07:19 PM
dac001's Avatar
thxs. Will look into that.
Old Oct 25, 2010 | 07:57 PM
dac001's Avatar
yep that's it .... thxs for the info/help...
Old Oct 26, 2010 | 06:06 AM
Imports14life's Avatar
Me too brother!
Problem #1: Its an Evo. Nothing is ever easy or goes right. Hope you get the problem fixed, sounds like a slew of dead batteries and push starts lie in your immediate future.
Old Oct 26, 2010 | 07:56 AM
gsrboi80's Avatar
Originally Posted by Imports14life
Me too brother!
As Chaotic posted and linked to sticky. Common issue that lies in the drivers kick panel due to water getting into connectors and causing corrosion. Nothing a solder gun and a tube of RTV can't fix
