RPMs dont fall when clutch is in?
Old Oct 26, 2010 | 02:08 PM
HFA_Ultima's Avatar
Hey everyone I have a issues with my new Evo. Its currently down because Im doing all the bolt ons but before when I would be driving it under a good ammount of throttle, trying to shift at around 4k-5k rpm the revs wouldnt fall. I could push the clutch in and the revs would stay at the same rpm for a couple seconds then drop down to idle. It wasnt erratic at all like a vacum leak but seemed more electronically controlled
Has anyone had this happen to them or heard anything similar? I dont know the history of the car but I pulled the fuel pump this weekend to put in my wally 255 and low and behold it already had one installed.
Old Oct 26, 2010 | 02:11 PM
laxplayer14's Avatar
look up throttle hang, its a common issue apparently for evo 8s and 9s
Old Oct 26, 2010 | 08:44 PM
Andrewkbmx's Avatar
throttle hang, nothing to be worried about, get tuned and it will be gone
Old Oct 26, 2010 | 10:22 PM
awdwannabe's Avatar
As stated above nothing to worry about. From what I understand its just the ECU burning off access gas that may be in the combustion chamber when the car is under a rich condition.. basically giving quite a bit of throttle then immediately pushing in the clutch.
Old Oct 27, 2010 | 05:35 AM
evo8426's Avatar
if it stays at the RPM then i would say you have a Tephra ROM which allows for no lifting off the gas pedal to shift. if it drops at a slower rate then i would say it is throttle hang which is fairly common.
Old Oct 27, 2010 | 11:44 AM
HFA_Ultima's Avatar
Ok well Im getting tuned this saturday will update after that, hoping to join the 400whp club!
Old Oct 27, 2010 | 01:36 PM
Boosted Tuning's Avatar
Just so you know, not all tunes will eliminate the throttle hang. And some tuners dont even know how to eliminate it.
Just be sure to ask your tuner to eliminate it.
Old Oct 28, 2010 | 02:21 PM
HFA_Ultima's Avatar
Ok thanks Im going to Mac Autosport in Colorado. Its a big shop that has done quite a few Evos according to them. I will ask if they can get rid of that
Old Oct 28, 2010 | 07:57 PM
awdwannabe's Avatar
Well.. if he had a QM twindisk clutch.. there's no tephra mod. needed for NLSing.. just the driver mod.
Old Oct 29, 2010 | 11:35 AM
HFA_Ultima's Avatar
I forgot to add this as well, it does NOT have a stock clutch from what me and a few people can tell. Its very very firm and doesnt grab until the pedal is almost fully released and it grabs hard.
Old Nov 8, 2010 | 10:52 PM
dsmagain's Avatar
might i suggest carz performace in lakewood for ur tune, great guys to deal with, havent heard much negative from them....
Lancer Driver
Lancer Engine Management / Tuning Forums
Feb 26, 2017 04:08 PM
ridenrunwv
Oct 3, 2015 07:54 AM
lawsy
Mitsubishi TC-SST Discussion
Jun 9, 2011 09:22 AM
amsevokid
Apr 19, 2010 07:17 PM
shiv@vishnu
58
Aug 11, 2005 05:40 AM
