evo 9 cranks but wont start
Old Nov 1, 2010 | 06:57 PM
loneracer05's Avatar
ivwill check that also but i do not think that is it because the engine will not start at all..it only cranks and cyl fires and continues to crank
Old Nov 2, 2010 | 12:37 AM
Outlanded's Avatar
you can ground pin 1 of the obd2 connector to give diagnosis through cel flash sequences.
just for info, my cam position sensor produced all the signals it needed to correct according to the mitsu service manual, did everything the same as your car is doing... so i would look more at that.
ground pin 1, with ignition at "ON" so your dash lights up etc. If theres a CEL, it will flash in sequence. No CEL it will just keep flashing on/off conistently fairly fast.
Old Nov 3, 2010 | 03:21 AM
Thanks outland I will definitely do that
Old Nov 8, 2010 | 10:43 AM
oneofakindracer's Avatar
try a compression test to see if your tbelt jumped on the crank
Old Nov 8, 2010 | 08:27 PM
well i took the time to checck the timing on the crank and im 75% sure it jumped 1-2 teeth on the tbelt.
Old Jun 6, 2011 | 07:57 PM
EVO8STI's Avatar
ever figure this out?
Old Jun 7, 2011 | 01:09 AM
Outlanded's Avatar
For me it was my camshaft position sensor.
Intermittent cel and code throw, test according to service manual and all results came back clear. Replaced it and not a problem in the last 7 months. According to Mitsubishi japan it's common for them to fail with age...
Old Jun 7, 2011 | 09:14 AM
My ecu was bad(blown capacitor) and also had fouled plugs
AutoXMRIX
Mar 9, 2016 07:02 AM
95teggsr
Feb 15, 2015 06:45 AM
Yazer
Nov 10, 2014 01:12 PM
EvoKevinEvo
Jan 30, 2012 04:56 PM
mot_bot
Jul 24, 2010 12:54 AM
