Evo 9 stalls out problem
Old Nov 3, 2010 | 10:05 AM
240sxzenki's Avatar
I know lots of people have this problem but I can't really fix the problem with my car. My car has intake, full turboback exhaust, forge bov and mbc, act clutch, cosworth cams and a full tune. Everytime i drive the car with the a/c on and come close to a stop or making a turn it will stall out on me specially in hot weather or after i beat on it. Anybody ever really fixed this problem on the evos. I know that there were people post this kind of threads before. Any inputs will be appreciated guys. Thanks
Old Nov 3, 2010 | 10:08 AM
binky's Avatar
Your ISCV tables need to be adjusted properly. Also, consider upping the idle more when the AC is turned on.
I had the same issue with my Evo and when I had it tuned, they also tuned my ISCV tables and now when I turn the AC I don't notice a difference at all.
-Bink
Old Nov 3, 2010 | 10:16 AM
kim.ry's Avatar
iac valve gone bad? my 8 had/have similar symtoms
Old Nov 3, 2010 | 10:43 AM
Ev0ikon's Avatar
Needs another "full tune".
Old Nov 3, 2010 | 10:53 AM
240sxzenki's Avatar
-Bink
This what I need to look into.
Old Nov 3, 2010 | 10:54 AM
240sxzenki's Avatar
I don't thinks it's bad. Since it doesn't throw out any cel. Plus when I don't have the a/c on, the car runs just perfect.
Old Nov 3, 2010 | 10:58 AM
240sxzenki's Avatar
-Bink
Do you have cams on your car? And what does ISCV stand for? Because most people I talked to they said because I have cams that's why it does that.
Old Nov 3, 2010 | 11:23 AM
gsrboi80's Avatar
ISCV Idle speed control valve. Not only that table but as mentioned you Target Idle w/ AC on may need to raised. What are the values now??
Old Nov 3, 2010 | 11:27 AM
4RETECH's Avatar
I had stalling issues.
See if you valve is cracked like mine was....
https://www.evolutionm.net/forums/ev...ge-my-isc.html
Old Nov 3, 2010 | 11:44 AM
240sxzenki's Avatar
I have no idea how to tell you that. Is there a way how to open up the Iscv table?
Old Nov 3, 2010 | 11:45 AM
240sxzenki's Avatar
like i said it only happens when i turn on the a/c. When a/c off the car runs normal.
Old Nov 3, 2010 | 12:10 PM
gsrboi80's Avatar
Do you have ecuflash sw and a data cable??
Old Nov 3, 2010 | 01:08 PM
240sxzenki's Avatar
No i don't. I guess I would need help from the professional then. I would love to learn how to do that myself
Old Nov 3, 2010 | 01:10 PM
240sxzenki's Avatar
I wouldn't mind spending times to learn how to do this
Old Nov 3, 2010 | 01:14 PM
240sxzenki's Avatar
So what i need is the ecuflash software and the data cable to be able to log on the data?
